Update: Just re calibrated the TPMS with the 18's and turned off stability control. Car feels much better at higher speeds however it does still feel odd when braking very gently at those speeds. I'm thinking the previous owner might of warped the front rotors. Anyone else having weird vibrations in their brake pedal when braking at speeds exceeding 110mph?
I got the iron rotors equipped on my vehicle. Def think the rotors are warped. The car stops on command at low speeds but the faster I go the more vibration I feel in the pedal. I've bled the brakes and it has made a minimal impact on what i'm experiencing.
I'm just going to use my 40% off discount at my local Chevrolet dealer and do OEM pads/rotors - Does anyone recommend another brake pad that will be better than the OEM Brembo pads?
You do realize this is a C5 forum you're posting in,,right?
Not sure how this is in the C5 forum. Might be a bug for you? Shows Corvette forum - Chevrolet Corvette Forum Discussion - C7 corvette 14-19 - c7 z06 discussion for me...
BLahdo - yes, you have posted this in the C5 General section. Not sure what is going on but if it happens again, we may want to get the forum’s Help Section staff involved.
