2nd gear grind
Old Nov 7, 2016 | 01:04 PM
Tksmooth's Avatar
Tksmooth
Default 2nd gear grind
2000 c5 53,000 miles. We ended up installing a mccloed clutch, new slave, synchros ,tick master and second gear(so I was told. I paid a tranny guy to do that part)anyways after doing the above mentioned work minus the tick master we had a grind into second at high Rpms and it was not fully disengaging at stop lights. So then I installed the tick master. Now it releases quite a bit late on the pedal and seems to fully disengage when pressed in. Grinding issue is still there at high rpm. So is the next step to pull the tranny and have the guy install upgraded Synchros or can I play with the adjustment some more on the pedal?
Old Nov 7, 2016 | 10:03 PM
El original's Avatar
El original
Suggest you post this in tech section. We only know about tires, waxes and how to get rid of mice in your garage. Hope they can help you.
