I have a set of 4 rims that came stock with the car, I was thinking about keeping two rims and put new tires on them, I don't travel far and I thought if something ever happened when I was out somewhere, I would know I had a spare at home.
Anyway how can I keep the tire mounted on a rim, and get a long life without dry rotting, can I leave them in my garage? it's not heated or cooled. Thanks
Spare tires are not needed....get a patch kit ($5.00), a portable compressor($15.00), a cell phone and a AAA Plus membership.
If you just want a spare tire, you could always pick up one of the late model GTO spares. They fit fine and are the same diameter as the front tire on my 2000 hardtop. (I did have to open the center hub hole a mm or two to get it to slide over the hub on the axle.) It will be a lot less expensive than buying two new tires and mounting them (not to mention storing them). If you have a couple of old tires you've replaced recently that may be worth doing.
http://www.ebay.com/itm/like/381818961790?lpid=82&chn=ps&ul_noapp=trueStore them in a cool, dry place, away from sunlight and ozone producing appliances and they should last a good long time without dry-rotting.
Good luck... GUSTO
Reason: added photo
I do have a can of fix a flat in my car, the thing is i don't want my car on a roll back, and most tire places don't have tires to fit without ordering them, that's why I was thinking about a spare in my garage just in case.
If you want to store spare tires but your garage is not climate-controlled, do you have space in a closet somewhere in your house to put them? If you want the tires to last longer, they need to be stored where the temp and humidity are regulated.
No not really, we have no space in house for two big rims
How many flat tires have you had in the past 10 years? For me it has been 3. I have driven ~400,000 miles in that time. None were so bad I couldn't fill with a compressor and continue to drive. One was a 1/4" bolt. It isn't worth having spare tire laying around waiting for something to happen. I do not have run flats on any of the vehicles I've driven and often leave the truck spare tire home because it collects snow under the truck. Don't like the weight or the fact it is holding snow against the bed of my truck.
Im doing it as a precaution reason, and I know the rim and tire are at home, I had one tire shread on interstate, it's not just flat tires, just precautionary reasons.
IF you want to keep a wheel/tire combo in the garage, you may want to store them in something like a large trash bag. Keep them inflated to the proper pressure and place them away from electric motors. Get a piece of plywood (30"x30") to place on the floor and put the tires on that.
Having a small 12v air compressor, a tire plug kit, and a can of "Fix-a-Flat" in the car is a good idea. That will get you going if you should get a puncture.
I don't think I would carry a spare tire and wheel in the car. It would take up a lot of room and you would have to figure out how to secure it. An emergency stop could make a spare tire in the back a missile...
If you did get a flat on the road, how soes the spare tire/wheel get out to you? Somebody at home? And how will you get the car up in the air to change the tire? With the car on a level surface, completely deflate a tire. Then measure the space between the ground and the bottom of the car. That gap is where a jack is going to have to fit so that you can change a tire. And a flat can happen where you may wind up parking the car on a soft or uneven surface.
Yeah either my wife of my mother, I will get a low profile jack. I dunno how going about doing this, I just don't know. Thanks
