2003 early/late
My question is what sequence numbers are considered early / late ?
Thanks in advance !
The fuel system in the 2003 was changed beginning about Nov 25, 2002.
https://www.corvetteforum.com/forums...post1576375429
Exact accuracy of the date and VIN in the above link has been questioned by a few on this board. Use the date and VIN as a general guideline of when the FFS system came into production.
Sensor issues have plagued all year C5's. Usually several treatments with Techron Plus will solve the sensor issues but on some occassions replacement of the sensors is necessary. Fuel pump replacement and sensor replacement on the later year 2003 and 2004 cars is a much bigger job than on the pre- FFS system. That is due to the need to drop the tanks to access any components inside the tanks. On the pre-FFS tanks there are access panels on the bottom back side of the tanks.
