Dumb Question but I need help..
Old Nov 23, 2016 | 01:01 AM
TXC5CHICK's Avatar
TXC5CHICK
Default Dumb Question but I need help..
So tonight turned really badly I was about to go shopping with my mom...of course today was rainy when all a sudden I heard this horrible sound I had managed to get a 3 by 5 chuck of metal stuck under my 98 vette in the plate under the passenger side... what is that plate called so I can replace it? When I was heading back home to attempt to pull it out I went over some tracks and it came off so I'm sure some other poor person is going to run it over but I'm mad bc I have a long cut under my car
Old Nov 23, 2016 | 02:15 AM
Crosis's Avatar
Crosis
http://www.gmpartsgiant.com/parts/gm...-89023042.html
Old Nov 23, 2016 | 03:35 AM
o2bnkc's Avatar
o2bnkc
I ran over a deer once and the antlers put a rip in the bottom of my floor. Crazy huh?! I just used some bondo to fix it. It's basically foam between two sheets of balsa wood. (or something like that) Just get some kind of filler to fix it. No biggie.
Old Nov 23, 2016 | 08:22 AM
TXC5CHICK's Avatar
TXC5CHICK
Thanks y'all
Old Nov 23, 2016 | 09:55 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by TXC5CHICK
Thanks y'all
did you ever get it running good ??
Old Nov 23, 2016 | 10:38 AM
TXC5CHICK's Avatar
TXC5CHICK
I finally got the A/C compressor fixed but now I gotta replace the blend door; I need to look on here on how to do that I would like to get that done over my Thanksgiving break; just got two new front tires; only thing I need to get fixed is the computer and now that panel under the car...
Old Nov 23, 2016 | 10:43 AM
enoniam's Avatar
enoniam
There was a rather good-sized puncture (about halfway through) in one of mine where it looked like a previous owner had chosen a bad spot to put a jack. Had a guy who had done some restoration work to a coworkers '64 repair it. He charged me under $200.
Edit - give yourself more credit - that wasn't a dumb question!
Old Nov 23, 2016 | 10:44 AM
TXC5CHICK's Avatar
TXC5CHICK
That's really not bad I just want it fixed because I'm crazy OCD about my cars being perfect.....
Old Nov 23, 2016 | 11:32 AM
Good luck getting it fixed. A good body shop should be able to make it look like new again.
Old Nov 23, 2016 | 09:42 PM
yoshgixxer's Avatar
yoshgixxer
You don't want to deal with replacing that part, it's bonded to the floor bracing and a bitch to get out. Repair it. It's nothing more then fiberglass, any decent body shop can repair that and make it smooth again.
Old Nov 25, 2016 | 01:40 AM
striper's Avatar
striper
The floor is actually two thin sheets of metal with balsa wood laminated between them. I don't know that the part of the floor you see is replaceable. I'm sure it can be cosmetically repaired, it won't affect the function of the car. I've dented mine in one spot up front, I've just left it alone. Lower your car so you won't be able to see it.
To Dumb Question but I need help..
