FrostBite 3.0 build thread.
Projects already or about to be in progress:
Interior
-Going from a firethorn interior to an all black interior with custom touches
-Installing aftermarket seats (still making my selection)
-modifying and shortening my factory auto shifter to accept a c6 style manual ****
-Swapping steering shafts to accept a newer style c6 Steering wheel
-Modern double din radio setup
Performance
-A&A Vortech V3 kit install
-Upgrading the fuel system
-Kb Boost A Pump
-60lbs injectors
-Ported Throttle Body
-Built 4l60e and stall (more built that current crappy build)
and if the budget allows will be going to a wide rear fender and possibly a carvaggio wing and export tails
Feel free to follow along. Ill have pics of the interior build posted tonight as its well under way.
Shifter installed (still waiting on boot, shifter is back off to be cleaned and rethreaded now)
New Radio Installed, its a JVC unit I had in another vehicle. It has all sorts of features including bluetooth audio and a call connection. I ran a microphone up through the a pillars and into the top of the car where it will pick up for hands free calling.
Currently working on swaping steering shafts to accept this c6 wheel. Getting there but its been a process. (broke a bolt off in the column tilt pin and having an ordeal getting it out.)
then Ofcourse, my true love... my one and only.
Should be wraping up the wheel project and installing the redline good boots here in the next few days. Also redoing my LEDs in my HVAC panel while i have everything out. Should have some progress pics in a day or two!
ones. Good luck as you move forward. Will be watching for updates.
Not to bad at all... had i known beforehand theres a method to pulling the pivot pins id have saved myself a ton of time but I broke off a bolt in them and spent about a week and $150s in drill bits un-@$#! that mess lol
