[Z06] Problems with HUD
Old Sep 19, 2002 | 10:48 AM
Cyclist's Avatar
Cyclist
6th Gear
Default Problems with HUD
I can not find information on what all the different symbols signify. The owner manual does not state what the symbols are and if they come on what that means.
The bar of lights on the right is suppose to match the fuel indicator right? If the little oil light is on what does that mean? If the engine coolant light comes off and on shouold I be concerned?? The dash indicators seem fine.
Maybe my HUD has gone bad. Any knowledge would be appreciated.
Old Sep 19, 2002 | 11:18 AM
jerryv's Avatar
jerryv
Default Re: Problems with HUD (Cyclist)
The gauge indicator on the HUD might be fuel, or it could be a couple of other things, like coolant temp or oil temp .. depends on how you've got the HUD display set up. This is described in the owners manual.
Most of the indicators are pretty self-explanatory. If you're seeing things on the HUD that don't match gauges or the DIC display, you may have a problem.
Be aware that when sunlight hits the HUD at a certain angle, it can appear to light up. If you see a warning indication on the HUD, check the DIC to see if it matches.
