LED Bulb Swap
Old Dec 14, 2016 | 02:12 AM
02GoldVette's Avatar
02GoldVette
Default LED Bulb Swap
Hello guys...
Quick question, I want to change my 02 Vette's rear view mirror bulbs and the sun visor bulbs to led white..
How do you I remove the bulbs from both?
And what led white bulbs do you guys recommend?
The picture below is of my rear view bulbs..
Old Dec 22, 2016 | 08:54 AM
VendettaC5's Avatar
VendettaC5
Carefully remove the lens covers on visors using like a jewlers (Eyeglass) screw driver set. There's little plastic tabs that just need to be pried off. Some on her said to then make a small lasso with string or dental floss around bulb to pull off. Didn't work for me I had to use a small pick and eventually got the damn things out. Visors are kind of flimsy so just use caution.
Old Dec 22, 2016 | 02:17 PM
Tsumi's Avatar
Tsumi
For the mirror LEDs:
http://www.digitalcorvettes.com/foru...ad.php?t=31485
https://www.corvetteforum.com/forums...r-led-mod.html
Only attempt if you're confident in your electrical knowledge and soldering skills. Otherwise, send it to one of several forum members or vendors that do that service.
To LED Bulb Swap
