Head light adjment lowered C-5
Old Dec 16, 2016 | 10:58 AM
radar502's Avatar
radar502
Default Head light adjment lowered C-5
Am I the only ne having this prop.?? 04 Z lowered all way down on lowing bolts the back lowered a little also .. The way I see it if 04 lowered have to rise the low beams to compensate for the lowering of the ride height so if you rise the low beams that puts the high beams too high witch is the prop. I am having and vice visa ,am I missing something.. When Adj . right now much for lights anyway . No not rising the 04.. Thanks
Old Dec 16, 2016 | 11:10 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
If you lower your C5 an equal amount, front and rear, you shouldn't have to adjust your lights. An inch or so lower won't affect your beam coverage significantly. Even if you do raise the lights slightly to accommodate the low beams, the highs aren't going to lose much, if any, coverage.
