3 position switch on center console
Old Dec 21, 2016 | 07:59 AM
grampi50's Avatar
grampi50
Default 3 position switch on center console
In my many C5 searches I have noticed that some cars have the 3 position switch and some don't. The switch has something to do with suspension stiffness (the switch is labeled "touring", "sport" and one other, I can't remember what the third position is called), but I thought all of the C5s came with this feature?
Old Dec 21, 2016 | 09:49 AM
Fast Cop's Avatar
Fast Cop
I believe that is the F45 suspension option. PITA.
Old Dec 21, 2016 | 09:51 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Selective Real Time Damping
(SRTD) (Option)
You may have a ride control system on your vehicle
called Selective Real Time Damping (SRTD). The
system provides the following performance benefits:
 Reduced Impact Harshness
 Improved Road Isolation
 Improved High-Speed Stability
 Improved Handling Response
This switch is on the center console. Turn it to select the
suspension characteristic of your choice.
TOUR: Use for normal city and highway driving. This
setting provides a smooth, soft ride.
SPORT: Use where road conditions or personal
preference demand more control. This setting provides
more “feel,” or response to the road conditions.
PERF: Use for performance driving. This setting
provides a tight, firm ride and precise response to
road conditions.
You can select a setting at any time. Based on road
conditions, steering wheel angle and your vehicle speed,
the system automatically adjusts to provide the best ride
and handling. Select a new setting whenever driving
conditions change.
There are three Driver Information Center (DIC)
messages that are displayed when a malfunction occurs
with the SRTD system. Refer to “DIC Warnings and
Messages” in the Index.
Old Dec 21, 2016 | 09:54 AM
jackthelad's Avatar
jackthelad
Tour, Sport and Perf. F45 adjustable shocks. An option - not cheap on base models. Replaced almost at the end of the C5's life by the F55 system - precursor to today's magneto rheological shocks.
I have it on mine - still functioning after about 80k miles, though all 3 settings are softer than they used to be. I really like it - tour is perfect for long highway runs (can't tell you how many people have said "I can't believe how comfortable this car is"), and then I turn it up a notch for the local twisties.
Old Dec 21, 2016 | 10:49 AM
Velocity_Vette's Avatar
Velocity_Vette
More C5s came equipped with Active Handling than they did F45 Selective/F55 Magnetic ride, as Active Handling was a much cheaper option (cost around $500 for Active Ride). Eventually, Active Handling was made "standard" later into C5 production.
F45 Selective Ride was an option from 1997-2002. In 2003-2004 F45 was replaced with F55 Magnetic Ride, which supplied shocks filled with magnetorheological fluid. The magnetorheological specific shocks are VERY expensive to replace - well into four figures for a full set - and you can't just throw standard shocks on a C5 outfitted with F45/F55 due to the electronics involved (it requires the option to be "deleted").
While F45/F55 does produce actual noticeable changes in suspension based on driver's input I specifically did not want this option when I sought out my C5. I actually passed on two really good cars equipped with it. Without it you can easily beef up FE1 equipped C5s with anything from Z51 cars to C6 Z06 parts and not have to worry about dealing with an option delete.
Old Dec 21, 2016 | 12:56 PM
ALLEGRO's Avatar
ALLEGRO
The F55 suspension first available in 2003 is hardly changed and in wide usage today. Ferrari, Cadillac and others (including some trucks) utilize a remarkably similar system to that of 14 years ago.
I will add that I LOVE mine and assure that there is a significant difference between the two modes.
Old Dec 21, 2016 | 03:40 PM
jackthelad's Avatar
jackthelad
F45 is easily defeated by tuning it out with a Tech II, or using resistors to fool the system. Getting rid of F55 is rather more complex. If the F45 shocks on mine start to fail, not at all sure what I will do, as I do like the adjustability.
Someone may have some NOS replacements some where.
Old Dec 21, 2016 | 04:28 PM
Smoken1's Avatar
Smoken1
Getting rid of the F55 is just as easy as the F45 with a Tech II
Old Dec 21, 2016 | 04:57 PM
grampi50's Avatar
grampi50
That's pretty much what I was wondering about...is this something else I should look for as another possible thing that could go wrong and wreak havoc...should I avoid cars that have it?
Old Dec 21, 2016 | 05:27 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
my 17 year old 99 with 70,000 has that and AH and everything works as it should !!
Old Dec 21, 2016 | 11:36 PM
o2bnkc's Avatar
o2bnkc
Two of my c5's came with the f-45 suspension (including my current 02) and I can't feel the difference on this one or my other one when I change modes.
Old Dec 22, 2016 | 12:20 AM
Rabbitman's Avatar
Rabbitman
There was a post here a while back from a poor guy who actually paid $4200 at a dealer to replace his F45 shocks. I don't know if it was here or the Tech forum. But my God did you ever hear of anything that outrageous. They say the F55's are a little cheaper but honestly they scare the hell out of me but I'm new to all of this but learning everyday here.
To 3 position switch on center console
