C5 vs C7
Old Dec 23, 2016 | 10:01 PM
JAKE-SON's Avatar
JAKE-SON
Default C5 vs C7
C5-LS3, Cam+LT w/ X-Pipe vs C7-LT1, LT w/ X-Pipe
Old Dec 24, 2016 | 01:12 AM
Would be interesting to know how that C7 got 450 rwhp with just LT and X-pipe since it had 460 bhp with no mods.
Old Dec 24, 2016 | 03:39 PM
radar502's Avatar
radar502
I'm with you that can't be right .. To get 40more Hp to the rear you would need a lest 80 Hp if not a 100 HP you lose lots through the drive train so if you got say 80 and you lose 50% that would make something like that anyway not adding up .. I added a 100 HP to my LS-6 got around 40 - + to the real wheels.. That's on LMR rollers ..
Old Dec 24, 2016 | 04:17 PM
FASTFATBOY's Avatar
FASTFATBOY
I have a C5 Z06 with 385 whp, I have run 3 base C7's only one gave me any trouble and it was pretty much an even race. When I get the new engine together with cam, I will go hunting them.
Old Dec 24, 2016 | 05:30 PM
Phanni's Avatar
Phanni
did they know they were racing?
Old Dec 24, 2016 | 06:26 PM
FASTFATBOY's Avatar
FASTFATBOY
Im a good bit lighter with about the same power
Old Dec 25, 2016 | 08:02 AM
Shakeydeal's Avatar
Shakeydeal
True. You are ~160 lbs lighter, but he probably has about 15 more whp. Could be a drivers race.
Shakey
Old Dec 25, 2016 | 08:35 AM
Phanni's Avatar
Phanni
Originally Posted by shakeydeal
true. You are ~160 lbs lighter, but he probably has about 15 more whp. Could be a drivers race.
Shakey
460
- 385
75
Old Dec 25, 2016 | 08:38 AM
Forcedvert's Avatar
Forcedvert
50% loss? Um......no
Old Dec 25, 2016 | 09:28 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
460
- 385
75
He said 385 at the wheels. With roughly 15% drivetrain loss he's maybe 20hp less while weighing 160lbs less.
That's makes it pretty even.
Old Dec 25, 2016 | 10:11 AM
FASTFATBOY's Avatar
FASTFATBOY
460
- 385
75
460 crank hp is about 391 at the wheels if you use the 15% loss for drivetrain.
With me at 385 to the wheels and lighter you can see where it would be a close race. My 385 at the wheels "should" make about 450 at the flywheel(ish).
You should brush up on your math.
Old Dec 25, 2016 | 11:01 AM
Shakeydeal's Avatar
Shakeydeal
Old Dec 25, 2016 | 11:30 AM
FASTFATBOY's Avatar
FASTFATBOY
Shakey
I've seen where the non Z06 is around 3400lbs with no driver, I'm around 3100lbs no driver.
Old Dec 25, 2016 | 11:45 AM
Forcedvert's Avatar
Forcedvert
The "math" is right, reading and comprehension may be off a bit.
Anyhow your number for the c7 may be a bit off, plus it has a better drivetrain.
Old Dec 25, 2016 | 12:07 PM
FASTFATBOY's Avatar
FASTFATBOY
Dynos lol. Was that dyno run SAE or standard? The sheet doesn't show it.
Better drivetrain? In what way? The C5 drivetrain is bullet proof and has been proved so for many years now. You mean better because its newer? Its simple to make LT1 power with an LS6 with only bolt ons.
I personally saw a C7 Z51 auto with Extrude honed exhaust manifolds, ported throttle body and air intake make 407 rwhp on a dynojet with standard correction factor on a cool day. Same day I made 398rwhp standard correction factor(I had an SLP catback at the time). This was at a Cars and Coffee event at sea level in 50 degree air.
Old Dec 25, 2016 | 12:35 PM
chasboy's Avatar
chasboy
Oldtimer
FWIW East Coast Supercharging uses a 16-17% drivetrain loss.
Old Dec 25, 2016 | 12:41 PM
Forcedvert's Avatar
Forcedvert
Just something I googled, I'm sure you know what you are talking about, but there is more to going fast than hp, whatever you do to a ls6 they can do to a LT1 to stay just ahead
I have a cammed 383 ls6 with a supercharger, I would love any c7 to try me... but around here they are all way to old and won't go
My drivetrain was far from bullet proof, never really read that much, useuely you hear about people upgrading it along with the Hp using C6 stuff, but I'm far from an expert. So please excuse me if I was wrong.
To C5 vs C7
Old Dec 25, 2016 | 12:49 PM
FASTFATBOY's Avatar
FASTFATBOY
The only "other" component to going fast in a straight line other than horsepower is less weight.....the end. Traction does play a role, but going fast is how much weight is the power having to move?
Old Dec 25, 2016 | 01:04 PM
Forcedvert's Avatar
Forcedvert
Torque? Gears? Speed of shifts? As I said I'm no expert maybe I'm wrong. It seems to me there is more to it than peak HP numbers.
Old Dec 25, 2016 | 02:33 PM
PlanoLeMans's Avatar
PlanoLeMans
OK I will play. To a first approximation it is given by Huntington's Equation, 1/4 mile ET = 6.290 (weight/hp)^1/3, where weight is in pound and hp is the peak horsepower at the clutch (note other equations exists that give slightly different constant). The physical basis of the equation is described in a 1973 article entitled "On the Physics of Drag Racing" by G.T. Fox in The American Journal of Physics. So yes it is mostly all about HP and weight. The other bits, like torque etc... are secondary effects. This equation, indeed, tells us that a big torquey engines are at a disadvantage to a smaller high revving engine in racing if they both make the same power. You can see that in almost all racing series, a boosted car will beat a normally aspirated car. This also tells us why modern racing engines rev at insane rpm's; eg. F1 engines rev at 20000 rpm, top fuel dragster's redline is 9500 rpm. Not saying that these other factors are not important, they are indeed the main things between winning and loosing in somewhat closely matched cars.
