[Z06] Trans./rear difference
Old Sep 19, 2002 | 11:03 PM
karshop's Avatar
0karshop
Former Vendor
Default Trans./rear difference
Does anyone know what the difference is in a ZO6 trans. and rear compared to a standard LS1 trans. and rear. Are they the same?
Old Sep 19, 2002 | 11:48 PM
GOINRED's Avatar
GOINRED
Default Re: Trans./rear difference (karshop)
I know that the ratios in the transmission are different. :D :yesnod:
Old Sep 20, 2002 | 04:41 PM
Steve Row's Avatar
Steve Row
Cruise-In II Veteran
Cruise-In III Veteran
The transmissions are different. The M12 (Z06) starts with a lower (2.97) first gear and the spread is different thru out. Go to the Corvette Museum website for a complete breakdown. There is also some differences in the sycros.
I had read somewhere that the driveshaft and rear were also different (read: stronger). Recently my car was apart at the dealer. The rear was sitting on the floor and I could see that the ring gear has cuts in it that are not in the standard rear, even though the gear ratio's are the same (3.42).
To Trans./rear difference
