Brake rebuild
Old Dec 30, 2016 | 01:59 PM
Patches's Avatar
Patches
Originally Posted by Evil-Twin
Ed, attention to detail?????
I noticed the rotors look as if they were fly cut on a lathe .. but I think ( knowing you as I do ) you would not have them fly cut just to remove surface rust ( I could be wrong... but it would be the first time in my life I was ever wrong ) the thing I did notice however, is what appears to be the very steady hand of a very OCD person using a 90 degree grinder with an #80 grit sanding pad with attention to the sanding pattern.
They do look machined, but knowing you, you did these by hand. and they look perfect.
Good eye as usual, Bill. I took it to a shop that specializes in high performance vehicles and specializes in brakes. If you look closely, you'll notice circumferential cuts as well. I believe the process they use is to measure first then cut these on a conventional bench lathe to achieve the proper runout and take a minimal of material off. The secondary, radial sanding pattern you mention was also done by the shop. This was probably a finishing process they used (I assume a machine-mounted sanding pad to keep it true) to minimize the possibility of squeals. I've spoken with machinists who work on brakes and was told the cross-hatch pattern helps prevent grooving and squealing and helps the pad bedding process.
I checked them as best as I could here and they were very nicely refinished. I measured before and after and they ended up taking a little more thickness than I thought they would - .020"-.030" total per rotor, so .010"-.015" per side. They are still comfortably above minimum thickness, though.
Old Dec 30, 2016 | 02:00 PM
The Chev's Avatar
The Chev
Originally Posted by Patches
Flawed or not, that was my thinking.
Thank you! I really appreciate the input.
Old Dec 30, 2016 | 02:14 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
They look beautiful....
Old Dec 30, 2016 | 04:13 PM
Patches's Avatar
Patches
Thanks for all the comments and questions, guys.
Btw, I noticed no one asked me about the back sides of the rotors. Well, of course, I attacked those with the same passion I did the fronts. Also, note that I went the extra mile after spraying the rotors and painted the individual holes with a brush to ensure they got enough coverage as well.
Back side of rotors
Old Dec 30, 2016 | 04:17 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Like we thought you didn't do the backs !!!! Com'on Man !!!!
Old Dec 30, 2016 | 04:19 PM
Evil-Twin's Avatar
Evil-Twin
Back side of rotors
Did you use a q-Tip... that's what I use....keeps the holes from bleeding rust.
Old Dec 30, 2016 | 04:22 PM
Patches's Avatar
Patches
Small artist's paint brush Carole gave me. Seemed . . . apropos.
Old Dec 30, 2016 | 06:33 PM
Patches's Avatar
Patches
Originally Posted by zguy
Very nice. I would like to do this to my car. I would powder coat the calipers black too. Can't wait to see how they look.
Since I won't be mounting these for a while, thought I would at least respond to this.
My C7 was the inspiration for the color. I like how the caliper doesn't jump out at you the way they do on my C5 currently.
C7
C5
Old Dec 30, 2016 | 11:46 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Amazing transformation from what you started with. Ed, what rims and sizes will you be ordering to go with the C6Z brakes?
Mike
Old Dec 31, 2016 | 02:02 PM
Patches's Avatar
Patches
Mike
Haven't decided but I have been talking to John at CCW recently for his input - big brakes require additional consideration. Plus, I am adding 1.25" front flares and 2" rears.
Old Dec 31, 2016 | 02:13 PM
IMXCITD's Avatar
IMXCITD
Nice work!
Old Dec 31, 2016 | 02:22 PM
Evil-Twin's Avatar
Evil-Twin
Is John back at CCW??? he sold that business a year and a half ago to speedline.. John went to build guns for the government.. John an I always talked a lot about building guns... one of his passions and mine... You told me via text you were talking wi8th John a few days ago. I didn't think anything of that, I just thought you talked with him at his home.
Bill
If John is back at CCW, that is great news for us...
Old Dec 31, 2016 | 02:47 PM
  #33
Patches's Avatar
Patches
Bill
I thought he mentioned when he sold the biz that he was staying on as GM or something of the sort. He responded to me via email and then phone this time around when I emailed him about my recent questions.
Old Dec 31, 2016 | 03:02 PM
  #34
Evil-Twin's Avatar
Evil-Twin
I thought he mentioned when he sold the biz to Weld that he was staying on as GM or something of the sort. He responded to me via email and then phone this time around when I emailed him about my recent questions.
strange, he was selling off some of his equipment two years ago to anyone wanting to buy.. Then sold the business... never once mentioned he was staying on in fact he said he had enough of building wheels.. The last few times we talked it was 90% about guns, suggestions for his wife's EDC, some of his likes and dislikes and building guns for the military, and 10 % about CCW.
Bill
Old Dec 31, 2016 | 03:55 PM
  #35
Mike98SilVert
Will you add brake ducts as well? The flares will give your car a whole new wicked and custom look. And you can add some really wide rear rims and tires for traction with that beast. Are you staying with polished rims or go with Black rims or something else?
Old Dec 31, 2016 | 04:30 PM
  #36
Patches's Avatar
Patches
Bill
He signed the email with "john" and also left me a VM and it sounded like him so . . .
Old Dec 31, 2016 | 04:34 PM
  #37
Patches's Avatar
Patches
Not planning on brake ducts at this time. I am planning on 13" rears and 10.5"-11" fronts (if those will work). Maybe 18"/19" as the tire profile gets so thin at the 19"/20" size and I'm not wanting the rubber band tire look. Not sure about finish yet but the brakes kinda' give you an idea where I'm headed.
