LS6 Intake manifolds
"...the modifications to the camshaft broaden the torque curve yielding a big boost in torque at the low end."
Also keep in mind not only did '01 get the LS6 manifold but it got a larger 85mm mass air meter and better exhaust manifolds compared to the older welded clamshells. Like I said, the '01 made more power in Spite of the cam.
1997-2000 C5 LS1:
- Intake / Exhaust Duration @ .050": 202 / 210 Degrees
- Intake / Exhaust Lift: .472" / .479"
- LSA: 117 Degrees
2001-2004 C5 LS1:
- Intake / Exhaust Duration @ .050": 199 / 210 Degrees
- Intake / Exhaust Lift: .467" / .479"
- LSA: 116 Degrees
1997-2000 C5 LS1:
- LSA: 117 Degrees
2001-2004 C5 LS1:
- LSA: 116 Degrees
If you can drive a C5 like an S2000 and high-shift through corners, than you honestly belong on a race-track full time! For pretty much everyone else, the tweaks were a positive thing... Not that it matters that much when you start modding your car and the intake and exhaust are the first to go!
They made up for it in terms of HP by adding the LS6 intake parts and 241 heads. I would imagine having to install only one kind of intake system was more cost effective.
I am pretty sure the later LS1's came with slightly larger LS6 injectors as well (from 25 to 28.6 LBS).
The more HP you add the more benefit you will get.
1997-2000 C5 LS1:
- LSA: 117 Degrees
2001-2004 C5 LS1:
- LSA: 116 Degrees
C5 camshafts:
'97-'99 LS1 .479/.472 lift, 207/199 duration, 117 Lobe Separation Angle
'00 LS1 .500/.500 lift, 209/198 duration, 115.5 LSA
'01-04 LS1 .479/.467 lift, 207/196 duration, 116 LSA
'01 LS6 .525/.525 lift, 211/204 duration, 116 LSA
'02-04 LS6 .551/.555 lift, 218/204 duration, 117.5 LSA
2000 camshaft was given more lift and duration to compensate for the inclusion of pre/pup cats on California and north eastern United States sold vettes to comply with emissions requirements. All '00 LS1s got the larger camshafts, but only those sold for delivery in California or north eastern USA, got the hp robbing pre/pup cats installed.
