ABS and Traction Control light
Old Jan 5, 2017 | 05:34 AM
Omaha Flash's Avatar
Omaha Flash
Default ABS and Traction Control light
My '01 convertible most recently came up with an ABS and Traction Control warning light. It had the C-1214 code which indicates a problem with the EBCM, (electronic brake control module) After doing some research I found out about The ABS Fixer (absfixer.com). I contacted Brandon and he assured me that a repair could be made quickly and my problems would go away. Fortunately he is located about 50 miles from me so after removing the module I drove to his location and while my wife and I had lunch he made the repairs and called me to advise the unit was repaired. I am very pleased to say after I reinstalled the module everything is back to normal. He also installed a surge protector to help eliminate the possibility of future problems. If you have a problem with your EBCM I would strongly recommend you contact Brandon for the repair.
Old Jan 5, 2017 | 05:42 AM
SG Lou's Avatar
SG Lou
Now that's what I call service !
Old Jan 5, 2017 | 05:45 AM
Omaha Flash
I can't say enough about the service Brandon provides. Very professional.
Old Jan 5, 2017 | 09:58 AM
friou's Avatar
friou
Thank you for the info, I've put into my "might need it someday" file. Always nice to hear of someone who provides a service/product that actually performs and provides good customer service. Seems its getting harder and harder to find. Thanks again and be well!
Old Jan 5, 2017 | 10:37 AM
runner140*'s Avatar
runner140*
Some have it and some don't.
Old Jan 5, 2017 | 01:01 PM
Vanover's Avatar
Vanover
Used them for my Silverado,did a great job,FAST.highly recommend them.
To ABS and Traction Control light
