Rear suspension noise.
Old Jan 7, 2017 | 12:26 PM
thfrider's Avatar
thfrider
Default Rear suspension noise.
Okay, I'm going to try again since my last few threads have been removed?????? After I drive my 04 for about an hour, I start hearing a knocking noise from the left rear at slow speeds. It sounds like a suspension issue because I only hear the noise when the wheel moves up and down (speed bump, pot hole etc.) It does not make the noise when I get in it and run around town for a short time????
Old Jan 7, 2017 | 12:38 PM
Joe Scafide's Avatar
Joe Scafide
Default rattle
try shaking the back side up and down had same problem loose shock at top slapping frame
Old Jan 7, 2017 | 04:01 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Also check your sway bar bolts.
To Rear suspension noise.
