Why not get a used LS3 since you will be rebuilding it any way. Then you would have heads, intake and all that good stuff. Unless you are planning going completely aftermarket which is more expensive.
What are your goals?
used ls3 is going for over 5k
i have an ls6 right now and i was about to put like 7-8k in mods to it but than i thought i might as well build a forged ls3
Beefing up the drive line is not cheep. RPM has some nice differentials built with C6z internals and other upgrades. If you are using really sticky drag tires then the applied torque can be hard on drive-line parts. I'm not much into racing anymore. I'm okay with the LS6 for now if anything ever happens to it I will probably opt in for an LS3.
Maybe someone who really knows the drive-line weaknesses and has broken a few parts will chime in.
You could get a forged stroked ls6 long block, ported heads, cam specd' how you want all put together from a reputable builder for about what you listed so far. What are your power goals? lots of built crazy horsepower ls6 out there without going to a ls3.
I got mine from SDPC for under 7k
im not sure what are my goals, its hard to imagine what that power feels like, drives like. whats your 1/4 mile time and trap speed?
I would just buy a complete long block (maybe w a warranty) of what you want, save all the headaches, unless you can do the work yourself and are good at it.
Increasing your HP 20-25% would definitely be noticeable but not so much that it is so hard to imagine. It's only 60 cubic inches and a little better intake and heads.
I could appreciate the better low to mid-range torque of the LS3 vs the LS6 on the street.
going from 370whp to 600 whp is a pretty big difference more than 25%
I assumed you were at the limits of the LS6.
600HP naturally aspirated is pretty radical. Probably not the best street manners.
This why we asked what your goals are. Is most of your driving going to be done above 4500 RPM? I am assuming High compression.
Since you're starting from scratch, why not look at an already built long block, such as the ones TSP offers? Would save a lot of headaches and would be turnkey
thats why im hesitating to put any money into an ls6, im affraid down the road i will want to increase the power but will need to spend big time
will the transmission and differential need to be changed if i do go to and ls3? im not talking about 800hp stuff, more 550-600
If that is the only power you are looking for, stay with the centri.
Your motor with headers, meth will hit those hp goals at 7psi with a safe tune it will last. As I told you last time I'm on my 04z stock motor, ECS installed Novi 2000 with AR headers, hi flows, X pipe, meth all stock cooling system at 6psi 581whp 515tq. 9 years, 20,000 miles always passes inspection and drives 100% stock and never runs hot. If and when motor goes will keep same 346 and just forge it and massage heads.
Crank Reluctor = 24x
CAM Wheel = 1x (Make sure you have the right one installed.)
--or make sure they are 58x and 4x and use LPE converter box.
Different injectors are used (ls3) (and use EV6>EV1 converters)
MAF / MAP / CAM sensor wires must be moved or get the adapter kits
Intake Manifold LS3
Throttle Body LS2 (silver blade) or 3bolt to 4bolt adapter
Get the rear oil galley plug from SCS vettes (i think thats them)
LS3 valley cover with orings to block oil towers
If you are building the block and it will be stroked, pick up a different windage tray unless you plan on hacking yours up to fit it.
Rear end is a different story - will cost as much as the engine or more.
RPM or RKT can help you with it
yeah after looking at their site the ls3 turn key engines are like 14k!! and not even forged
i would choose supercharger but i cant give up the sound of an n/a
