battery problem?
Old Jan 14, 2017 | 05:27 PM
jay c smith's Avatar
jay c smith
Default battery problem?
My wife has a 99 triple black 6 speed with 30,000 miles . The car sat for 3
months without a tender, because of her major surgery. The car was second on my mind. When I thought about her car, of course , her car would not start. Turn the key and nothing. I had purchased a hand held charger
from Ecklers that would start a dead battery. It did. I drove it for about
20 minutes and put it in the garage. Tried to start it again, no start. I put tender a tender on it. The reading on the car , when started was 14.4
down to 9.6 volts, which made me worry. Today it started up reading 14.5,
drove it another 20 minutes and watched the voltage gradually drop to 13.8. Any suggestions? Thanks, Jay
Old Jan 14, 2017 | 05:53 PM
IMXCITD's Avatar
IMXCITD
battery could be going....stick it on a regular charger and let it fully charge and see if it holds the charge.
Old Jan 14, 2017 | 06:12 PM
racebum's Avatar
racebum
go to costco and buy another low cost battery. you can afford to replace every 2 years there for what it would cost you to buy one higher end one every 6
sitting dead for 3 months and especially if it's more than 3 years old. why risk it? it's also hard on the alt if the battery won't hold a charge
Old Jan 14, 2017 | 06:15 PM
JR-01's Avatar
JR-01
Also a tender is used to maintain the charge. Not so much to charge a dead battery.
Old Jan 15, 2017 | 02:50 PM
SuperTom's Avatar
SuperTom
Yeah these cars seem to drain the battery quick when sitting. I got a cheap solar panel kit from harborfrieght for like $15. Keeps the battery good if its going to sit for a while and doesn't use my electricity like a tender. http://www.harborfreight.com/15-watt...ger-68692.html
Old Jan 15, 2017 | 03:25 PM
El original's Avatar
El original
Battery is Kaput! That means it is Toast. Gone to the happy battery hunting grounds, lol. Replace and you will be at peace!
To battery problem?
