Aftermarket Seat Help
So I am in the market to replace my factory c5 z06 seats for something a little more comfortable/performance driven. The issue I am facing right now is finding a seat that will fit in my car. I have looked at a ton of different posts here on the forum, but it seems that there are a few posts that contradict each other. I just want a straight forward answer of what seats fit and will work with the OEM three point seat belt.
So what I am hoping the good people of the corvette forum will do for me is just post what performance seat they have in their car, without getting to personal height and weight. Personally I am 6’3’’ tall, 250lbs, and have a size 38 waist.
Thanks in advance
The first question is do you want a street style seat that will recline or a fixed back seat more geared for track use?
Reclining seats there are very few options that just drop in. More options are available if you are willing to do a C6 seatbelt conversion.
Most fixed back seats will drop right in as there is no reclining mechanism to interfere with the seatbelt reel on the floor.
http://www.toquez06.com/corbeau.html (this thread will show both ways to mount the A4's without the bracket mod and with)
My current A4's.
However, because the bracket modification moves the seat further toward the center console it does limit the travel of the seat backward. At 6’3” you may not be able to move the seat far enough back for your comfort. I am 6’ and it is just enough for me.
The alternative with the A4’s is to leave the bracket as is but reverse mount the seats, that is to mount the driver’s seat on the passenger side and vice versa. However, this leaves the recline levers for each seat between the seat and the center console and difficult to access without attaching a ring/pull to the lever.
The third option is to convert to the C6 seat belts which eliminates the floor mounted recoil mechanism and frees up enough room to mount the A4’s or other similar seats on the correct side and without moving the seat any closer to the center console. However, this does mean you have to modify the B-Pillars to remove the area that originally covered the floor mounted recoil mechanism.
I am in the process of converting mine to the C6 seat belts and replacing the A4’s with a set of seats from Braum (below), once I get some color samples from Braum to make a decision.
That is what i have heard about the A4s. the seats look good though!
(skip the ad)
Just not enough to spend the dough to replace them. But the C5 seats are just plain awful for any sort of spirited driving.
I am 6" 250 lbs and 36-38" waist depending on the day. The seats are snug in the shoulders, but I don't mind so much. I consider it a trade-off in getting the 1" shaved base to get my vision out of the sun-visor.
I was hesitant to modify the trim pieces, but I am so excited after feeling real seats in my car, that I am no longer afraid to cut the factory pieces.
The Evo seats look nice, but I want to get away from leather. I'm too leery on a fixed back setup since I wouldn't want to be stuck with a seatback position I'm not in love with.
I am 5"11, 38 inch waist, and 230 pounds, and love the comfort of these proper sport seats, which the C5 should have had from the factory, rather than the Chevy Cavaliere seats that it came with.
How is the microsuede wearing? I like that as an upgrade over the base material and definitely don't want leather. I personally also like how the Corbeau logo is embroidered
into the seat as well.
So, yes, once I take them back out for a few more mods, I will go into more detail. and yes they are plug and play, just not up to the level of fit that I expected.
Have you noticed this as well?
I have no issues with the seat belt retraction, no interference with the seat shoulder area.
And yes, the Corbeau A4 barely fits in there, it is a tight fit against the door-sill plastic trim where the belt reel bulge is.
