02' Coolant change question
Old Jan 29, 2017 | 02:28 AM
Gmanh's Avatar
Gmanh
Default 02' Coolant change question
Planning a coolant change on my 02' C5 with 75k miles. Been thru the posts on procedure. Will probably do a simple drain and fill. Not clear on filling the system.
1 gallon of pure Dex Cool and the rest distilled water?
2 gallons of 50/50 Dex Cool and the rest distilled water?
What will give me the best mixture?
Car is in Sothern CA, frequent trips to Phoenix.
Thanks to all - Glenn in San Diego.
Old Jan 29, 2017 | 05:47 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
COOLING SYSTEM BLEEDING
1. Fill system through radiator surge tank opening up to base of fill neck. Start engine and idle
for one minute. Install radiator surge tank cap. Cycle RPM from idle to 3000 in 30 second
intervals until engine coolant reaches 210°F (99°C). Shut off engine.
2. Loosen radiator surge tank cap. After all hissing stops, remove cap. Start engine. Idle engine
for one minute and fill surge tank to between FULL COLD and FULL HOT. Install radiator
surge tank cap. Cycle RPM from idle to 3000 in 30 second intervals until engine coolant
reaches 210°F (99°C). Shut off engine. Top off coolant as necessary.
Old Jan 29, 2017 | 09:35 AM
JR-01's Avatar
JR-01
Originally Posted by 8VETTE7
When you drain the cooling system on the C5 you get only about 50% (6 to 7 quarts of the approximately 12.5 quart system capacity) of the coolant out of the system. The other 50% is still in the block and cannot easily be removed because there are no block drains. You therefore have about 50% of the old coolant still in the system in a 50/50 mix. So what you would want to do is fill the system with a fresh 50/50 mix to retain an overall 50/50 mix.
On the other hand you can flush the system multiple times with distilled water so that what remains in the block is nearly 100% distilled water. In that case you would want to add about 6 quarts of full strength coolant to get approximately an overall 50/50 mix. (6 quarts of distilled water in the block plus 6 quarts of full strength coolant yields an approximate 50 /50 overall mix) Then top off the coolant with a 50/50 mix to retain an approximate overall 50/50 mix.
Since the car never gets close to freezing temps, is a 50/50 mix necessary? Wouldn't a more diluted mixture cool better in that area with higher temps?
Old Jan 29, 2017 | 10:40 AM
narlee's Avatar
narlee
It's anti-corrosion additives are also a plus.
Old Jan 29, 2017 | 10:52 AM
JR-01's Avatar
JR-01
How do you know the temps never get close to freezing?
There are some relatively high altitudes that must be passed through between SD and Phoenix. In winter those altitudes can easily be freezing or below and at speed the air passing through the radiator can produce very cold temps capable of freezing and well below. If it were my car I wouldn't take the chance. I run a 50/50 mix all year and I live in the part of Az that gets to 110+ in the summer. But it also gets a few winter nights that are in the 20's. YMMV.
50/50 is good to 34 below, 40/60 is good to 15 below and 30/70 is good to 5 above. I should have said it doesn't get much below freezing. In that hot climate I would run 60/40 and not worry about it freezing just to get better cooling.
Manufacturer's recommendation:
The standard recommendation is to use a 50/50 mix of antifreeze and water. This represents a compromise between cooling efficiency and the ability to prevent the mix from freezing during cold weather. After all, the initial purpose of antifreeze is to prevent freezing.
But a 50/50 mix does not give the best cooling. For improved cooling in hot weather, we should use less antifreeze and more water, perhaps going to a 25/75 or a 20/80 mix ratio.
Everyone knows antifreeze prevents corrosion, and corrosion is bad. True enough. But, even a 10/90 ratio of antifreeze to water will serve the puproses of inhibiting corrosion, at least according to one source of information.
Old Jan 29, 2017 | 10:59 AM
c4cruiser's Avatar
c4cruiser
The factory Dex coolant fill is a 50/50 mix and GM tested the C5 (and the C4's) cooling system in very hot and very cold conditions. You can get pre-mixed Dex in gallon jugs and that makes it easy to do the drain/fill process.
Get a couple of the pre-mix gallon jugs and you will be fine.
Old Jan 29, 2017 | 11:29 AM
JR-01's Avatar
JR-01
So just how would one calculate a 60/40 mix on a drain and refill assuming that the original mix in the cooling system was 50/50?????????????
Hardly seems worth the effort IMHO.............
Some guesswork and then using a coolant tester. Doesn't have to be exact. I ran a diluted mix in my C3 in the summer and it lowered operating temp by 5 to 10 degrees. I guess I would not be all that concerned about getting exactly 50/50 in a hot climate like his. Just make sure it's good for winter temps. That's where the tester comes in.
50/50 was an industry wide compromise to handle all climates.
Old Jan 29, 2017 | 12:09 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I use 2 gallons of pre-mixed 50/50 Prestone Dexcool. No hassle.
http://www.iammoon.com/c5tech/coolant_drain.htm
Old Jan 29, 2017 | 01:05 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by JR-01
50/50 is good to 34 below, 60/40 is good to 15 below and 70/30 is good to 5 above. I should have said it doesn't get much below freezing. In that hot climate I would run 60/40 and not worry about it freezing just to get better cooling.
I run 65/35 distilled/Dex with one bottle of water-wetter in a 17 qt system with Dewitts radiator.
Old Jan 29, 2017 | 08:43 PM
David Shiel's Avatar
David Shiel
Very Helpful. Somehow I got the misguided idea that it required some special piece of equipment and have not flushed mine. I'll give ya a jingle tomorrow.Today went crazy. Just now settling down.
Dave
Old Jan 29, 2017 | 08:52 PM
David Shiel
Default There you go!
The additives protect water pump seals and bearings, thermostats, control valves, etc. If it calls for 50/50, do 50/50.
Dave
To 02' Coolant change question
