My vet has a leak at the rear and front seal of the engine.
How difficult it is to change them
And what else to check at the same time.( clutch,slave cylinder.....?)
Thanks for your help
135000 miles.
I think it is necessary to remove the front axle and the transmission and it is the labor which is expensive. Then if everything is removed it is better to change what could break.
135000 miles.
you mean the steering rack in front(not the axle(none) ?? at this point I would do a complete overhaul with a new clutch !! Sure many more will chime in !!!
