1300rwhp project
Old Feb 3, 2017 | 10:14 AM
401AK47's Avatar
401AK47
Default 1300rwhp project
Almost done, Hood will be modified over the Winter.
Everything checks out.
Runs awesome, but will need to be tuned to for max power in the Spring.
Will be tuned by Fran at Race Proven in the spring.
  • ATK Forged Internals LQ4 408 Iron Block - Manley Rods/Piston/Crank - Tool Steel Pins - ARP Bolts
  • High Performance Water pump
  • Melling Oil Pump
  • 160 T-stat
  • ECS Stage II Ported 243 heads (11:1) - Comp 921 Dual Springs - Studded - Rocker Arm Trunnion Upgrade
  • Holley Valve Covers
  • F1R ProCharger - ECS Bracket (22lbs) - Will switch to a 2-bar Speed Density sensor once I get it on the dyno at Race Proven in Delaware.
  • ECS 8 rib Pulley set up
  • ID1000s (65# fuel pressure - brings the IDs to approx. 127lb injectors)
  • ECS Dual Nozzle Meth Kit
  • Dewitt Radiator / Dual Fans
  • ECS Oil Cooler
  • Custom Fuel System- Aeromotive Eliminator - Paralleled with in tank stock pump (with Kenne Bell Boost Pump module) -10 AN Supply to -8 (Holley Efi Rails) to -10 AN return.
  • RPM Transmission Level VI
  • B&M Shifter
  • DTE Trans Brace
  • LS2 90mm Throttle Body
  • Hardened Output Shaft (both)
  • Monster LT1R Twin Clutch 1200rwtq
  • LGM Longtube Headers
  • Holley High Ram Intake
  • England Green Whiplash II cam
  • Holley Efi Fuel Rails
  • Hi Flo Cats
  • B&B Bullet Cat Back
  • Nitrous Express Plate, Window Switch, Controller, Bottles
  • Aeromotive Fuel Pump Controller
  • Innovate SCG-1 Boost Controller
  • Tial 50mm BOV
  • Pfadt Coilovers
  • Pfadt Swaybars
  • C6 Z06 Front Brakes (SS Lines)
  • Baer Eradispeed +2 rear Brakes (SS Lines)
  • A&A Intercooler
  • Caravaggio Seats
  • Caravaggio Rear Spoiler
  • LG Rear Fenders
  • Tiger Shark Front Cap
  • iForged Wheels 19x10 (275/30/19) 20x12.5 (345/25/20)
Old Feb 3, 2017 | 10:16 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
DAYUM!!!
Old Feb 3, 2017 | 10:17 AM
401AK47's Avatar
401AK47
Old Feb 3, 2017 | 10:22 AM
401AK47's Avatar
401AK47
The intake tube to the high ram will be replaced after its dynoed to a straight tube, band clamps will be toggle bolt clamps. I Just stuck those on so I dont get into too much during break in.
Old Feb 3, 2017 | 10:34 AM
blackmachdown's Avatar
blackmachdown
Warning keep small children away from the blower inlet!
Old Feb 3, 2017 | 10:37 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Wicked, love to hear it !!!
Old Feb 3, 2017 | 11:20 AM
LoneStarFRC's Avatar
LoneStarFRC
  • LQ4 408 Iron Block Forged - Manley Rods/Piston/Crank - Tool Steel Pins - ARP Bolts
  • Melling Oil Pump
  • 160 T-stat
  • Ported 243 heads (11:1) - Comp 921 Dual Springs - Studded - Rocker Arm Grunion Upgrade
  • ECS Oil Cooler
  • B&M Shifter
  • DTE Trans Brace
  • Hi Flo Cats
  • Tial 50mm BOV
  • Pfadt Coilovers
  • Pfadt Swaybars
  • A&A Intercooler
  • Caravaggio Seats
  • LG Rear Fenders
Nice list...
Well, except for one thing maybe. Your rocker arm grunions sound kinda fishy to me. Go to the beach much??
Old Feb 3, 2017 | 11:22 AM
401AK47's Avatar
401AK47
Trunnion lol its a typo. It's fixed.
Old Feb 3, 2017 | 11:51 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Big bore of a 408 yet using 243 heads?
Why not take advantage of the much better rectangle port heads out there? Same price as 243.
Did you get custom spec piston skirts to help the fact they will be below the cylinder @ full travel? There's a reason GM went with longer sleeves on their 4" stroke LS7 block. Your skirts will be below the cylinder almost to the oil ring and rock to one side, then get slammed upward. Not healthy.
Old Feb 3, 2017 | 12:01 PM
401AK47's Avatar
401AK47
ATK 408.
Appreciate the inputs, but I'm confident it will be fine.
Old Feb 3, 2017 | 12:56 PM
95wht6spd's Avatar
95wht6spd
What wheels/tires are you going to use?
Old Feb 3, 2017 | 12:59 PM
401AK47's Avatar
401AK47
For street the 20s
For roll ons, at set of 18x12 C6 w/ drag radials
If I actually race it. I will go the LG drag spindle/15" route.
Old Feb 3, 2017 | 01:30 PM
v8srfun's Avatar
v8srfun
Nice
Old Feb 3, 2017 | 02:34 PM
zeevette's Avatar
zeevette
You're crazy. I like that.
Old Feb 3, 2017 | 06:41 PM
williame3590's Avatar
williame3590
Sick sick car...........love it!!!
Bill
Old Feb 3, 2017 | 09:50 PM
Damn, that is a lot of HP on tap.
Old Feb 3, 2017 | 10:28 PM
Rob 02's Avatar
Rob 02
A hole HP for every 2.5 lbs. damn!
To 1300rwhp project
Old Feb 4, 2017 | 12:01 AM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
Wow...intense power and one great looking Corvette,
Old Feb 4, 2017 | 12:18 AM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
Sweeeeeeeeeeeeeeet, L8R ZFLASH
Old Feb 4, 2017 | 01:11 AM
StingrayRebel's Avatar
StingrayRebel
a liberal's worst nightmare, I like it
