Sun Visor Retainer Clip Replacment??
Old Feb 4, 2017 | 01:25 PM
Jeff Weber's Avatar
Jeff Weber
Default Sun Visor Retainer Clip Replacment??
Hi all,
wondering if any of you guys know of any aftermarket replacements for the retainer clip for the sun visor. Pretty much anytime I get on the gas pretty good the sun visors alway fly off into my face. If anyone knows of like a quick fix or something to stop this issue any advice would be much appreciated. Just the way GM designed these things there's nothing to hold them in place under extreme acceleration, kinda silly.
Thanks!
Jeff
Old Feb 4, 2017 | 03:43 PM
mwestc5's Avatar
mwestc5
If you can't track down the the part you need, there's always Velcro
Old Feb 4, 2017 | 05:54 PM
twokbolt's Avatar
twokbolt
Had the same problem. Bought an OEM replacement off Ebay. Cheapest thing I think I've bought for the car. Swaps in easy.
Old Feb 4, 2017 | 07:57 PM
o2bnkc's Avatar
o2bnkc
Got mine off of ebay
Old Feb 4, 2017 | 09:04 PM
Carl Timonen's Avatar
Carl Timonen
How about here?
http://www.vettenuts.net/index.php?l...t_detail&p=195
Old Feb 5, 2017 | 02:05 AM
o2bnkc's Avatar
o2bnkc
That will work. Corvette Central sells them, too.
Old Feb 5, 2017 | 04:52 AM
Here's a little trick I used until I broke down and bought an OEM replacement. I just wrapped a small piece of black electrical tape around the end of the metal rod that slips into the opening of the retainer clip and then inserted it into the clip. A couple of layers is all it takes. This provided enough grip to keep the sun visor tight in the clip. You will not notice the tape one the rod is seated in the clip.
Old Feb 5, 2017 | 04:55 AM
Jistari's Avatar
Jistari
Cheap OEM part (not used only in Corvette....so the still stock them)
Old Feb 10, 2017 | 05:20 PM
gr1634's Avatar
gr1634
Default Sun Visor clip
Isn't there a difference between right and left?
Gr
Old Feb 10, 2017 | 11:50 PM
No, the clip will fit on either side.
Old Feb 11, 2017 | 02:39 AM
striper's Avatar
striper
The clips are around two bucks. Get them at the dealer, only one screw to replace them.
Old Feb 12, 2017 | 09:03 AM
gr1634's Avatar
gr1634
Default sun Visor Update
Passenger side clip broken. Read the info in here and called the dealer yesterday. Clips are indeed the same whether left or right - dealer had one in stock. I went for it immediately - $3.38. Forum rocks!
Gr
Old Feb 13, 2017 | 03:45 PM
whalepirot's Avatar
whalepirot
7mm hex head.
Old Feb 14, 2017 | 10:17 PM
Rabbitman's Avatar
Rabbitman
Originally Posted by Carl Timonen
Thanks, mine are worn also. I'm glad somebody found them.
I've had the same problem with the ones on my MG MIDGET
To Sun Visor Retainer Clip Replacment??
