Hatch wont open 2004 base model
Old Feb 4, 2017 | 07:19 PM
1998SN95's Avatar
1998SN95
Default Hatch wont open 2004 base model
ok ive seen all the post about adjusting the springs thats not my issue. i need to adjust the hatch because the back glass was busted out. After it was replaced the hatch wont open it looks like it moved back towards the rear of the car and now is catching on the rear. Do i just pop the plastic cover off on the inside of the car right above your head to adjust the hinges? i just need it moved less than a quater inch?
Old Feb 4, 2017 | 07:40 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
there is a release wire behind the drivers rear speaker.
Old Feb 4, 2017 | 07:53 PM
1998SN95's Avatar
1998SN95
[QUOTE=Pounder;1594023799]there is a release wire behind the drivers rear speaker.[/QUOT
The wire just helps open the hatch correct? i need to adjust it so it wont catch at the back of the car.
Old Feb 4, 2017 | 07:57 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
[QUOTE=1998SN95;1594023901]
well I thought you could not open it ??? once open you might see adjustment. I don't understand how the hatch got misaligned by the window breaking ??? my car is covered so I have not looked at it.
Old Feb 4, 2017 | 08:07 PM
1998SN95's Avatar
1998SN95
[QUOTE=Pounder;1594023926]
im not sure either but after the install of new glass and sitting for 24hrs and a drive down the road it will not pop open, you basically have to pop it and pull it at the same time because its in a bind on the back tail section.. it just needs to be slide back about an 1/8.
Old Feb 4, 2017 | 08:24 PM
1998SN95's Avatar
1998SN95
Well clearly safelite didnt know what they were doing thanks for the info. i plan on calling them monday to see what i can have done.
Old Feb 4, 2017 | 08:25 PM
Carl Timonen's Avatar
Carl Timonen
Was the hatch removed to install the glass? If so, it's possible that some shims might of been misplaced.
Old Feb 4, 2017 | 08:30 PM
1998SN95's Avatar
1998SN95
no not at all old glass was removed new glass was installed with hatch shut and then opened to check the rubber seal.
Old Feb 4, 2017 | 08:57 PM
Choreo's Avatar
Choreo
How was the glass broken out? Are you sure it was opening alright just before you had it replaced?
I watched them replace my rear glass at the dealership and it did not affect the hatch alignment?
Old Feb 5, 2017 | 03:36 AM
1998SN95's Avatar
1998SN95
Default Busted glass
It was busted out with a golf club. Somebody decided to vandalize it. It open fine before it was busted...
Old Feb 5, 2017 | 08:34 AM
David Shiel's Avatar
David Shiel
Default I take all my glass work to the SAFELITE in
North Charleston, SC. They have a dedicated Corvette Glass specialist and will not even make me an appointment with any other tech. The guy really knows his Corvettes right down to special sealants used on a C5 windshield install. I will follow him whereever he goes--like a stalker. He did mine recently and it was perfecto in all respects. They even let me watch by backing it into the shop so I could see all from the shop door.
Dave. I then got a CS call and later one by mail. BEWARE who you let work on your car.
Dave
Old Feb 5, 2017 | 08:46 AM
1998SN95's Avatar
1998SN95
Dave
That's who my insurance uses thought then knew what they were doing even sent 2 people one was a supervisor
Old Feb 5, 2017 | 08:11 PM
David Shiel
Default You have 2 things going for you:
1. I have found that SafeLite stands behind their work i00%.
2. Your insurance company sent you there and should go to bat for you to resolve it with a proper fix.
It was an insurance job. If your hood did not fit perfectly after a front end skirmish, the insurance company would have to send in an adjuster and get it fixed correctly. That's why you pay insurance. DEMAND that it be properly repaired. If they say it is because of damage associated with the glass vanalism, still they need to treat it as a comp claim and fix it right.
DO not try to fix it yourself and insist on perfection.
Dave
Old Feb 5, 2017 | 08:17 PM
David Shiel
It was an insurance job. If your hood did not fit perfectly after a front end skirmish, the insurance company would have to send in an adjuster and get it fixed correctly. That's why you pay insurance. DEMAND that it be properly repaired. If they say it is because of damage associated with the glass vandalism, still they need to treat it as a comp claim and fix it right. They can send it to a Vette shop and get it properly repaired.
Dave
Dave
To Hatch wont open 2004 base model
