Headlight Bezel Screws?
Who sells replacement headlight bezel screws? I am talking about the (6) black screws that screw into the metal C-Clips behind the bezels that attach the bezels.
I have some metal Phillips-head screws that are the same size/thread, but the stock screws have a free rotating metal shrowd (like a cone-shaped attached washer) that keeps the screw heads from cutting through the plastic bezels when tightened.
Any chance that anyone would carry these locally? I live in Mole's Town!
There is probably a proper term for this type screw?
Received 19,301 Likes
'20-'21-'22-'23-'24
Check with one of the used parts vendors on the forum. Chances are they would have a few.
I think it is just called a trim screw & the washer is a countersunk or cup trim washer, non flanged.
Attachment 48061785
Attachment 48061785
The 2nd one from the left looks pretty close but the the ones in the photo look like they have a slightly convex Phillips head where the stock ones are flat head Phillips. Probably because of the tight clearance between the headlight bezel and the surrounding body panels.
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Choreo (02-09-2017)
