Several things happened at once!!
Old Feb 15, 2017 | 02:57 AM
John Barlow's Avatar
John Barlow
1st Gear
Default Several things happened at once!!
So upon starting my 2002 vette today I was getting a CHECK TIRE PRESSURE and REDUCED ENGINE POWER warning, MY power windows weren't working, The air conditioner wasn't putting out cold air, The oil and coolant temperature gauges were inoperable, and the traction control and ABS lights were on. NONE of these problems were present until I started it today. Could it be a blown fuse or something?
Old Feb 15, 2017 | 07:35 AM
Phanni's Avatar
Phanni
Likely a battery problem.
Had the car not been started for a few weeks, or is the barely old?
Old Feb 15, 2017 | 08:14 AM
friou's Avatar
friou
Check your battery, low voltage kicks off all kinds of funky stuff in C5's. Good luck!
Old Feb 15, 2017 | 09:18 AM
SuperTom's Avatar
SuperTom
Battery, Clean your grounds. This topic comes up once a week here
Old Feb 15, 2017 | 03:28 PM
bikeriderga's Avatar
bikeriderga
That or a grounding problem. Has it been exposed to rain/moisture?
Old Feb 15, 2017 | 04:34 PM
All of the above could be the source of the problems. I'd start with making sure the battery is in top shape.
Old Feb 15, 2017 | 09:16 PM
Not4spd's Avatar
Not4spd
Same thing happened to mine. It ended up being a wire that comes from the main harness to the door panel.
Post 7 has pics.
http://www.z06vette.com/forums/f4/re...indows-117419/
Old Feb 15, 2017 | 10:06 PM
c6miller's Avatar
c6miller
If the battery checks out okay, Check the ignition switch. Mine did the same thing and a new switch fixed everything.
Old Feb 16, 2017 | 12:29 AM
Rob 02's Avatar
Rob 02
Mine did that when my alternator died.
To Several things happened at once!!
