Hvac technical question
I'm installing a CD player and I have three preouts on the back. With the dash kit and the rcas out the back I'm about 3/4" from flush mounting. I've tried 90* rca adapters and adding the spacer to bring the CD player forward. I still don't have enough room. My next and I think only option is to cut into the hvac box behind the CD player. My main question is, what is behind it and how much room is back there? I plan on cutting out a big enough hole to get the space I need then create a pocket to reinstall back into the hole I cut into the hvac.
However I would look for a different set of RCA right angle adapters. I made a custom set for my install so nothing had to be cut.
Gary
I included a pic that another member put up so you can see what it looks like under the dash pad.
HTH,
Dan...
