1997-2004 C5 Corvette Hood Pad Decal Back In Stock
Platinum Supporting Vendor
1997-2004 C5 Corvette Hood Pad Decal $47.49 With Code PHIL5 At Checkout.
BACK IN STOCK!
Give your C5 Corvette a great new look when lifting your hood at those car shows with this C5 Corvette hood pad decal.
Important installation information: Due to the surface of the hood liner, this decal can only be successfully installed with time and energy to properly adhere to the hood liner.
1. Remove your hood liner from your C5 Corvette - this step is not optional!
2. Lay your hood liner on a table or workbench and make sure the temperature is 65 degrees or more.
3. Clean your hood pad by using a microfiber cloth and warm water. Gently remove any dust, dirt or grime.
4. Allow the hood liner to dry for 45 minutes to 1 hour.
5. Wearing gloves take a hair dryer or heat gun you'll now install the vinyl decal to your hood liner. Use quite a lot of heat to allow the vinyl to become softer and stretch in and out of the bumps and valleys of the hood pad liner. Massage the vinyl by going over and over every inch of the vinyl decal. Once complete, repeat this process again. Press firmly and use heat. Work back and forth. Make sure to cover the entire hood liner, work slowly and methodically.
6. Allow the decal to sit for 24 hours. The next day you'll want to go over any areas that have not fully adhered to the surface by using heat and pressure as you have done previously.
7. Make sure you do not install the hood liner for 24 hours after your final work on the vinyl decal of step 6. The vinyl decal needs 24 hours to fully adhere or it will fall off with engine heat.
BACK IN STOCK!
__________________
RPI DESIGNS, LLC. - C5/C6/C7 Corvette Parts
4000+ C5/C6/C7 Parts & accessories - Forum members get 10% off with SS2007 coupon at checkout
Like us on www.facebook.com/rpidesigns and you might win $100.
Our brand new C7 Corvette Z06 Style Side Skirts come painted in Carbon Flash Metallic, see them here!
email: rpi.designs.customerservice@gmail.com Web: www.rpidesigns.com
