Which wire set is preferred?
Old Mar 1, 2017 | 05:33 PM
lonerider2002's Avatar
lonerider2002
Default Which wire set is preferred?
I'm going to do the plug change myself and almost bought the red perf GM wires but I came across the MSD-32819 8.5mm Super conductor wire set and wanted to ask you all is one better than the other? Pricewise they are about the same and it appears that you do not have to use the metal heat shields with these. My 2002 coupe is mostly stock except for the catback BB Bullets. My credit card awaits your responses...
By the way-I'll be using the Iridium 41-110 plugs.
Thanks !
Old Mar 1, 2017 | 05:44 PM
soofrsh's Avatar
soofrsh
I'm using the red msd plug wires. I've had them on since October when I installed my headers. No issues since then.
Old Mar 1, 2017 | 05:49 PM
killian96ss's Avatar
killian96ss
MSD wires are good and have much lower resistance which equals more spark energy reaching the plugs. If the price is about the same I'd go with MSD.
Steve
Old Mar 1, 2017 | 06:01 PM
oemtech's Avatar
oemtech
Veteran: National Guard
I use Magnum wires with a soild stainless steel core and RF choke. Expensive when compared to stock... But you will never have to replace the. I also use stick heat shields.
Old Mar 1, 2017 | 06:13 PM
lonerider2002
Steve
I think that's the way I'll go--Thanks
Old Mar 1, 2017 | 06:25 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
GM red............
Old Mar 1, 2017 | 06:47 PM
dbgoodwin's Avatar
dbgoodwin
Literally virtually any quality wire will work perfectly fine. I used GM Reds and this most recent time I used some JBA performance wires because a friend had them brand new and pretty much gave them to me. They were 8.5mm and feel sturdy, so I'm sure they'll work just great.
Old Mar 1, 2017 | 11:00 PM
Fcar 98's Avatar
Fcar 98
Originally Posted by leadfoot4
gm red............
Old Mar 1, 2017 | 11:27 PM
I've run the GMPP red wires on my last two C5s and I have no complaints.
Old Mar 1, 2017 | 11:43 PM
Mike98SilVert's Avatar
Mike98SilVert
I currently use Taylor ThunderVolt 50 10.4mm Spark Plug Wires. I chose them because they have a low 50 ohms/foot of resistance. Plus, since I have LT Headers, they can withstand heat up to 600 degrees F. I added plug wire heat shields as well for added protection. I have absolutely no RF interference.
Old Mar 2, 2017 | 08:56 AM
lonerider2002
After some research I ended up getting the MSD's at Advance for about 56.00 after the discount-the Iridium plugs on Fleabay for 21.00 after the rebate & even sprung for 8 new heat shields from R/A for less than 30.00 (just in case they have never been out before & I lose my patience with 'em.). Not a bad investment and although a local mechanic said he'd change them out for 160.00 I think I'll do it myself.
I need to pull the EBCM out anyway so I'll do it all over an upcoming weekend.
I'll let you all know how things worked out.
By the way, the car has over 98000 miles on her and hopefully nothing will be fused together.
Old Mar 2, 2017 | 10:40 AM
dbgoodwin's Avatar
dbgoodwin
10.4 MM!? I like overkill as much as the next guy, so I'm interested.
I'm actually serious about that too, that sounds kinda awesome, although if I went much thicker than the 8.5mm wires I have I'm pretty sure that the wire would be sitting on the header primary.
Old Mar 2, 2017 | 02:00 PM
DTA4's Avatar
DTA4
What is the red gm part # and will they fit 03 z. Want to put in before headers next year
Old Mar 2, 2017 | 03:31 PM
Cutlassmaster's Avatar
Cutlassmaster
I installed OML wires after removing the GM red ones. Very happy with them and no issues.
Chris
Old Mar 2, 2017 | 04:13 PM
Mike98SilVert
That's why I installed the heat sheilds/socks whatever you call them. The shields I chose withstand up to 1800 degrees F.
Old Mar 2, 2017 | 06:32 PM
steig's Avatar
steig
GM Red here
Old Mar 2, 2017 | 07:25 PM
SuperTom's Avatar
SuperTom
GM Reds on mine for 8 years. Now that I think about it probably time for a new set soon.
To Which wire set is preferred?
