Anyone Installed Roll Hoops - Question
Old Mar 4, 2017 | 08:28 AM
peteinpa's Avatar
peteinpa
Default Anyone Installed Roll Hoops - Question
Hi folks, for those of you that installed themselves, what bonding agent/product did you use? Thanks.
Old Mar 4, 2017 | 09:53 AM
novasscnc's Avatar
novasscnc
I have them they were already installed not sure of the adhesive, Mid America should have what you need, take your time cutting the carpet they did a bad job on mine I made carpet donuts with Velcro to cover the mess up.
Old Mar 4, 2017 | 12:58 PM
regalvette's Avatar
regalvette
You can order the heavy duty epoxy from Mid America. I chose to screw mine in, but be careful as the gas tank is behind the mounting area. I made a paper template to cut the carpet it came out perfect that way.
Old Mar 6, 2017 | 10:08 AM
peteinpa's Avatar
peteinpa
Thanks for the responses guys.
Old Mar 6, 2017 | 01:13 PM
clyons's Avatar
clyons
Default Hoops
If you use screws make sure they are short. If they are a bit to long they will punch a hole in the gas tanks.
To Anyone Installed Roll Hoops - Question
