Seat Belt Warning Light
Old Mar 4, 2017 | 01:48 PM
xman57's Avatar
xman57
5th Gear
Default Seat Belt Warning Light
My seat belt warning light will not go out when I'm buckled in. Does anyone know the reason why?
Old Mar 4, 2017 | 05:52 PM
xman57's Avatar
xman57
5th Gear
Originally Posted by 8VETTE7
Sounds like the seat belt switch is stuck in the "closed" position. The switch is a part of the connector on the female (latch) part of the seat belt mechanism. When the tongue end of the belt is inserted into the latch the switch is supposed to open the circuit so that the light on the dash goes out. If the switch is stuck closed the light remains illuminated even when the belt is latched. The connector that contains the switch is between the seat and the tunnel at floor level.
Thank you very much
Old Mar 4, 2017 | 11:50 PM
Great info. Thanks and will keep this for future reference.
Old Mar 4, 2017 | 11:53 PM
hron61's Avatar
hron61
^^^ yeppers, me too. bookmarked.
this place just ooozes good stuff.
Old Mar 5, 2017 | 07:15 PM
RedWhitefast's Avatar
RedWhitefast
https://www.corvetteforum.com/forums/c5-tech/3498497-seat-belt-light-fix.html. Put this up a while back but caught flack since you can just unplug it
Old May 11, 2020 | 11:11 PM
Sunwarrior's Avatar
Sunwarrior
Just what I needed.
To Seat Belt Warning Light
