Need a little help - no start
Old Mar 11, 2017 | 11:53 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Default Need a little help - no start
Well, went into town on a date and after a good meal, unlocked and got in. Everything was fine, placed the key in the switch, seat automatically adjusted, dash lights up, depressed the clutch, turned the key to start - and absolutely nothing - no start, no clicking, lighting did not dim - nothing. Key turned to start position so the column isn't locked.
2001 coupe, M6 215,000 on the clock. I'm thinking with those miles the starter just suddenly went bad - but I'm not a mechanic - don't even know where the starter is located to check the connections. The battery connections are tight and it's a new battery - all the lights work and nothing is dimming. Only other thing I can think of is the clutch switch may not be disengaging - but I really don't have a clue.
Need a little help. - THANKS
Old Mar 12, 2017 | 12:26 PM
ZEEZERO-6's Avatar
ZEEZERO-6
bad ignition switch = https://www.corvetteforum.com/forums...ch-repair.html
Old Mar 12, 2017 | 01:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Mar 12, 2017 | 01:26 PM
ZEEZERO-6's Avatar
ZEEZERO-6
Originally Posted by Pounder
is this for replacing the clutch switch ? Mine does what the OP's does but not very often and I to thought it was the clutch switch myself but was told it was the ignition switch ?
Old Mar 12, 2017 | 01:42 PM
Black 02's Avatar
Black 02
Similar situation happened to me, replaced the starter and it never happened again. It would only do it while hot, never when cold. I believe I used a new bosch starter from autozone with the updated design, but it's been several years.
Here is how my car acted before I fixed it.
Old Mar 12, 2017 | 02:14 PM
ZEEZERO-6's Avatar
ZEEZERO-6
https://youtu.be/6Tz5Sx2Hqn4
interesting, one of these days something is going to give and I will be SOOL
Old Mar 12, 2017 | 02:24 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
[QUOTE=Black 02;1594282664]Similar situation happened to me, replaced the starter and it never happened again. It would only do it while hot, never when cold. I believe I used a new bosch starter from autozone with the updated design, but it's been several years.
What no swearing ?????
Old Mar 12, 2017 | 05:07 PM
Black 02's Avatar
Black 02
My neighbors probably heard a thing or two
Old Mar 12, 2017 | 05:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
yes it's the clutch switch !!
Old Mar 12, 2017 | 08:05 PM
ZEEZERO-6's Avatar
ZEEZERO-6
Thanks for your help
To Need a little help - no start
