Is it really that simple?
Old Mar 12, 2017 | 11:48 AM
57gman's Avatar
57gman
Default Is it really that simple?
To remove the C5 seats, just remove the front black covers, unscrew the front and then back screws, disconnect the power and carefully pull out? I watched a video on you-tube, and that's what they showed!
Just need the right tools, is it that simple?
Old Mar 12, 2017 | 11:49 AM
joe's98's Avatar
joe's98
St. Jude Donor '15, '17
Yes it is. I have taken mine out several times.
Old Mar 12, 2017 | 11:55 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Yup, had both of mine out...
Old Mar 12, 2017 | 12:15 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
if it's power run the seat all the way up, a lot easier to work on the seat if that is what your doing !!!
Old Mar 12, 2017 | 12:50 PM
loufernh's Avatar
loufernh
It also helps to remove the top, to get the seats out.
Old Mar 12, 2017 | 01:40 PM
It's not hard at all. I would recommend you have the steering wheel all the way forward (if you have the telescoping wheel) and you place a blanket over the door sill area to prevent any possible scratches.
Old Mar 12, 2017 | 02:01 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Just a couple of thoughts.. Yes its 4 nuts and a power cord. One trick is to remove the power cord last.
1. run the seat all the way back to remove the front nut cover, then remove the 2 nuts.
2. run the seat forward and remove the two rear nuts. ( no covers. )
3. reposition the seat in the center of the seat rails. ( to make the smallest foot print for removal )
3. if you can, remove the top ( Targa ) or lower the top, ( Vert ). it will make things easier to remove and reinstall
4. VERY Important !!!! make sure you cover your rocker panels. ( those seat rails are very sharp )
Bill aka ET
I know a few things because I have seen a few things
Old Mar 12, 2017 | 06:02 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
And just to cover all of the potential liability claims, DO NOT attempt the seat removal while the car is in motion.
Old Mar 12, 2017 | 06:15 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Mar 12, 2017 | 06:50 PM
Phanni's Avatar
Phanni
Easy, however the nuts can be very tight.
Old Mar 12, 2017 | 07:27 PM
chasboy's Avatar
chasboy
Oldtimer
Yup, it says so in the preamble of the manual. Trust me
Old Mar 12, 2017 | 07:57 PM
Macleod52's Avatar
Macleod52
The hardest part is unplugging the power connectors.
Old Mar 12, 2017 | 08:03 PM
SG Lou's Avatar
SG Lou
Yup
Old Mar 12, 2017 | 08:17 PM
57gman's Avatar
57gman
To all of you, THANK YOU VERY MUCH. At the end of the month, I'll be taking them out to give to an experienced upholsterer to fix the rocking issue and put on the new jute pad, new foam and new leather, can't wait.
You guys are great!
Old Mar 12, 2017 | 08:51 PM
Frank4202's Avatar
Frank4202
I mine out once a year to vacuum.
Old Mar 13, 2017 | 08:36 AM
ZO6 cracker's Avatar
ZO6 cracker
You guys are great!
I will be removing my Z06 seats also to have them redone soon.
Old Mar 13, 2017 | 08:40 AM
leadfoot4's Avatar
leadfoot4
Sounds like a personal issue................
To Is it really that simple?
Old Mar 13, 2017 | 11:18 AM
chasboy's Avatar
chasboy
Oldtimer
Show off.
Old Mar 13, 2017 | 11:21 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
you are my Hero !!!!
Old Mar 13, 2017 | 12:20 PM
unlvrebel's Avatar
unlvrebel
Only once? Guess I should stop eating in the Vette...
