Shifter Question
Old Mar 15, 2017 | 08:11 PM
My04's Avatar
My04
6th Gear
Default Shifter Question
I have an 04 Vette C5, A/T, the shifter moves freely. I have everything removed, but then I don't know how to determine what's not connected or needs to be fixed.
Would you explain or send a picture, so I an determine what's wrong ???
Old Mar 15, 2017 | 08:16 PM
My04's Avatar
My04
6th Gear
Thanks in advance,
Help !!! No ride until I fix it !!!!!
Please & Thanks
Old Mar 17, 2017 | 10:32 AM
nsogiba's Avatar
nsogiba
I'm no A4 expert but it sounds like your shifter cable is broken/not attached. I hear it's a fairly common problem. You can find much more info with a search on here.
https://www.corvetteforum.com/forums...o-replace.html
Old Mar 17, 2017 | 01:32 PM
bonzo's Avatar
bonzo
St. Jude Donor '12
Literally just had this happen to my 04. The shifter cable is being swapped out as I type this. It was still connected at the tranny but was wearing right off under the actual shifter.
Old Mar 17, 2017 | 06:01 PM
Vanover's Avatar
Vanover
There are plastic grommets on both ends,one on the shifter,one on trans end.check those first. Common problem. Auto parts store has them. dormon) pack has a bunch of diff.sizes but the ones you need are in there.
Old Mar 17, 2017 | 10:27 PM
Sure sounds like a problem with the shift cable.
Old Mar 18, 2017 | 12:03 AM
c5dominic's Avatar
c5dominic
Definitely shifter cable, either the shifter end or the transmission end...
That piece of orange was part of the original bushing...
Old May 19, 2017 | 06:59 AM
My04's Avatar
My04
6th Gear
Default Fred
What a story : I finally went to our local Chev. Dealership, I know I shouldn't of, just don't have the correct jacking tools. Should of went and bought them. First of course I needed a new shifter, total $635, $200 in addition to put a/c belt on. Now the-shifter was used (said they told me, maybe true, getting a little old). When I left dealership, radio didn't work, messed up a piece of trim, a/c indicator not illuminating, and most importantly the FNG indicator on the used Shifter didn't work. To shorten the rest, after 3 trips to the dealership (myself buying aftermarket shifter, new). Suppose to get reimbursed, I have my Vette back. They gave me a code to fix the radio. But they couldn't do it. So I fixed radio, after 2 days and the rest didn't get fixed. Got to get a part for a/c !
On the third trip I went to dealership, found the Service Manager (for the last time), I was asking to speak to GM or owner, he took me into his office and started to talk. I cut over him immediately and began chewing him out. Got the Vette 3 days later
STAY AWAY FROM PERFORMANCE CHEVROLET IN ELIZABETH CITY, NC .
Old May 19, 2017 | 09:32 PM
c5dominic's Avatar
c5dominic
Wow that's really crappy, I did mine in my garage, took me about 2.5 hours, dropped the exhaust and everything.
Old May 19, 2017 | 09:57 PM
c5dominic's Avatar
c5dominic
Wait what, a new shifter? why
To Shifter Question
