stainless bolts
Old Mar 18, 2017 | 11:13 PM
Tibber02's Avatar
Tibber02
Cruising
Default stainless bolts
Can you use new stainless bolts on a new water pump instead of factory bolts
Old Mar 19, 2017 | 01:46 AM
grantv's Avatar
grantv
Can't see why not. Find out the bolt grade (guessing just GR5), match in SS.
Old Mar 19, 2017 | 09:39 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'd check the ARP website, and not knocking the OP, but WHY?
Old Mar 19, 2017 | 10:15 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
not sure stainless and aluminum is a good mix ???
Old Mar 19, 2017 | 10:57 AM
momo20's Avatar
momo20
you will be fine imo , the aerospace eng. use them with everything that they build...boats use them for most all the fasteners that are used...so i really don't see any ill effects
Old Mar 20, 2017 | 09:13 AM
jackthelad's Avatar
jackthelad
Stainless are less likely to react with anything else than regular bolts. I've replaced a number of bolts on cars with stainless, where high grade bolts are not needed. Usually swing into Lowes with an old bolt and see if they have any for starters - they have both metric and inch sized stainless in my local store.
Old Mar 20, 2017 | 09:17 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
in my experience that wasn't the case, worked in a Baby Formula plant and they never-seized all stainless bolts or they could not get them out without breaking them off ????
Old Mar 20, 2017 | 10:17 AM
narlee's Avatar
narlee
I think the anti-seize is to prevent galling.
Old Mar 20, 2017 | 10:19 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Yes !!! that's why I said they react different than regular bolts/nuts ???
Old Mar 20, 2017 | 11:09 AM
lebeeby's Avatar
lebeeby
FWIW... Stainless and aluminum don't play real well together. You should use Tef-gel on the bolts to prevent electrolysis from welding the stainless to aluminum. I could be all wet, but you see that quite a bit in a marine environment. Of course if you aren't planning on sailing in your 'vette, the outcome could be different. Personally, I wouldn't take the chance.
Old Mar 20, 2017 | 11:44 AM
smartadze's Avatar
smartadze
All good advice! But what to take away:
1) MOST stainless bolts and hardware are rated LESS than Grade 5; much of that hardware-store stainless is unmarked and deficient as far as clamping force is concerned. There is also a lot of counterfeit Grade 5 Chinese stuff floating around, mostly marketed in custom-bike channels.
For real Grade 5 and Grade 8 stuff for high-strength applications, ARP is the only source I trust.
2. ALWAYS use anti-seize on any stainless bolt and/or nut.
To stainless bolts
