[Z06] timing chain/oil pump
Old Mar 22, 2017 | 10:51 AM
JBoyle997's Avatar
JBoyle997
Default timing chain/oil pump
Do any of you higher mileage guys plan on changing your oil pump or timing chains? Or have you yet just because of mileage? My buddies oil pump went in his ls6, blew the motor. Hes only at 40k. I guess age is a factor with these cars as well. Im at 75k and have tossed the idea around just wanted to get some feedback.
Old Mar 22, 2017 | 06:41 PM
dbgoodwin's Avatar
dbgoodwin
Wow, only 40k? I'm curious if something else happened such as oil contamination that caused the oil pump to fail. Was his car stock or modded? I'm borderline paranoid about oil temp/pressure, I check that more often than I check my speed even.
Old Mar 22, 2017 | 07:41 PM
JBoyle997's Avatar
JBoyle997
The car had a tick sns stage 3 cam and all the bolt ons
To timing chain/oil pump
