I need some work done...
Old Mar 29, 2017 | 09:38 AM
Alien c4's Avatar
Alien c4
Default I need some work done...
I hear a light front end "clunk" at low speed over small bumps. My mechanic says it's inner tie rod ends.
What's that job entail and what's ballpark cost?
Old Mar 29, 2017 | 10:23 AM
Vanover's Avatar
Vanover
It could be sway bar bushings.
Old Mar 29, 2017 | 10:44 AM
3sACROWD's Avatar
3sACROWD
I agree.
Did the mechanic get under the car and get his hands on things to make his determination or just listen to you and/or the car?
Old Mar 29, 2017 | 11:32 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
First thing I would do is get under the car with an impact wrench and tighten everything, including in the suspension. I had a similar problem and it was a slightly loose sway bar bolt.
Old Mar 29, 2017 | 12:12 PM
Smoken1's Avatar
Smoken1
Check the sway bar end links
To I need some work done...
