[Z06] Help me fix this!
Old Apr 4, 2017 | 08:51 AM
04zjimc's Avatar
04zjimc
Default Help me fix this!
my z is lowered on stock bolts 1 nub on the bushings are cut in the front. Car also had a alignment done.my tires are new all the way around. My problem is the passenger side has a little more gap than the drivers side...I really don't want to spend the money on used coilovers..how else can I fix this?if I have to buy coilovers used does anybody have any? Thanks jim
Old Apr 4, 2017 | 09:55 AM
Moto One's Avatar
Moto One
First off you can't see both sides at the same time. But maybe a wight balance would be more in line then trying to match fender to tire.
Mark
Old Apr 4, 2017 | 10:29 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Since people sit in the driver side it could be the spring itself is fatigued which has it biased to one side.
You can remove the bolt completely on the passenger side and it would get it closer.
Old Apr 4, 2017 | 11:14 PM
04zjimc's Avatar
04zjimc
I changed the front spring because my original one had rusted lowering bolts... so I bought a used one. Both springs did the same thing...
To Help me fix this!
