Cam...
Old Apr 5, 2017 | 01:54 PM
jbclutch's Avatar
jbclutch
St. Jude Donor '09-'12
Default Cam...
Have a LS1,stick car...What cam can I get that will make the bumping sound, nasty sound?..Like old school....
Old Apr 5, 2017 | 02:09 PM
feeder82's Avatar
feeder82
one with numbers close to this 230/237 .6×× lift 112lsa
Old Apr 5, 2017 | 02:32 PM
RBS_Z51C5's Avatar
RBS_Z51C5
Active Streak: 90 Days
MS4 or Tsunami comes to mind. If you can find one, the old TREX cam
Old Apr 5, 2017 | 03:16 PM
Cheesecake 07's Avatar
Cheesecake 07
FTI Streetsweeper. Shakes the car, idle is nasty and actually makes the power a healthy cam should
Old Apr 5, 2017 | 10:26 PM
FASTFATBOY's Avatar
FASTFATBOY
Thunder Racing TREX
Old Apr 6, 2017 | 12:07 PM
jbclutch's Avatar
jbclutch
what is the max lift I can use?
Old Apr 6, 2017 | 12:10 PM
Antz97znj's Avatar
Antz97znj
There's a billion out there, ask a vendor or shop they'll set ya up w/ something.
Old Apr 6, 2017 | 02:07 PM
jbclutch's Avatar
jbclutch
Default Cam...
MS4, cam is what we are looking at...
Old Apr 7, 2017 | 10:24 AM
cqd24's Avatar
cqd24
Another vote for MS4. I run the Torquer V2 and am very happy with it.
Old Apr 7, 2017 | 12:12 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Like old school? Never happen, different firing order.
Old Apr 7, 2017 | 04:33 PM
jmohn's Avatar
jmohn
For just the sound of an "old school" cam?
Just pull a plug wire.
Old Apr 8, 2017 | 02:21 PM
jbclutch's Avatar
jbclutch
Default cam
will I need to have it tuned, or dino?...
Old Apr 8, 2017 | 02:26 PM
cqd24's Avatar
cqd24
You'll definitely have to get it tuned. I'd consider a set of longtube headers as well if you go the cam route.
Old Apr 8, 2017 | 04:33 PM
kirk tarrant's Avatar
kirk tarrant
i just did a btr stage 4. nice and lumpy
Old Apr 8, 2017 | 08:15 PM
feeder82's Avatar
feeder82
tuned, different valve springs, lots of things you need to change while you have it apart. You didnt mention any other mods, how much lift depends, stock heads? when you start the mods, it never ends until you run out of money
Old Apr 9, 2017 | 07:22 AM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
I have Melrose LT Headers, X Pipe and Ti Exhaust... running the Torquer V4 and love it. Here's a couple vids:
Old Apr 10, 2017 | 10:42 AM
jbclutch's Avatar
jbclutch
Default headers..
yes Sir we will be..Thanks.
To Cam...
Old Apr 10, 2017 | 10:45 AM
jbclutch's Avatar
jbclutch
Default Cam...
https://youtu.be/fjNS-Akgi0M
https://youtu.be/UClEdfJbCFc
Sure sounds great..Did you replace the lifters and rockers too?
Old Apr 10, 2017 | 01:17 PM
FrankLP's Avatar
FrankLP
Miles of Smiles
Here's what went in for my Cam swap... would've liked to have done a bit more but was low on $$...
Texas Speed Torquer V4 Cam
.080 Chromoly push rods
Dual valve springs
Ti retainers & valve seals
Cloyes Race Billet True Roller Single Roller Timing Set
Melling high pressure oil pump
Old Apr 11, 2017 | 01:52 PM
jbclutch's Avatar
jbclutch
Dual valve springs
lifters are OEM?...Did they have the heads off?
