2003 50th Anniversary man. trans.
Looking to buy 2003 red Anniversary edition with man. trans. Any advice or things to look for or consider. Really like the looks of the car with the all shale interior and convertible top.
I think the AE Convertible is one of the the best looking C5s. I had to settle for an '01 Magnetic red vert with light oak top. Similar.
I own one myself and I love it. One thing to consider if it has any broken interior components is that it is difficult to source parts in the shale or neutral colors. I had to replace a vent grill in the dash pad and some of the small inserts at the interior door handles and they are only available in black. Therefore I had to buy the correct paint to match and paint these items. Additionally there are many great aftermarket goodies that are only found in black. With this said, I still love the Shale interior color and will live with the lack of color keyed items. Front and rear trunk and facia emblems are pricey as are the 50th emblems on the side if any of these are faded or missing.
Magnetic Ride Control was an included option on the 50th Edition and if the shocks go south they can be expensive to replace unless you do other options to repair. Mine has about 90,000 miles on it and the Magnetic Ride Control still works perfectly.
All in all, it is exactly like other '03 C5s and C5s in general. I hope you go for it and enjoy it.
Received 19,472 Likes
'20-'21-'22-'23-'24
Love the looks of the '03 AE cars. Good luck with your search and as 8VETTE7 mentions, read those stickies in his links.
A great interior paint match is from ColorBond
On an Anniversary interior the darker is GM Medium Dark Neutral # 153
and the lighter is GM Shale # 156.
I recently tried several such sprays and found ColorBond to be by far the best at matching the OEM colors. Clean the item well, wipe them down with Denatured alcohol after cleaning. DO NOT use rubbing or isopropyl alcohol as it contains oils that will harm the paint sticking. You will also need to purchase and use a spray Adhesion Promoter on the areas to be sprayed after the alcohol wipe down has dried. I suggest using one made by the same company as the paint. Once you have applied several light coats and have the coverage you want you also need to follow up with a spray Cleat Coat. Again it is best to use a CC made by the same company and to follow the recommended dry times between coats on all three steps.
Perfect match in my 50th Aniv.
Received 1,679 Likes
Make sure the Shock Stuffers have been removed.
jrprich (04-06-2017)
Thanks for all the great advice! Am reading up on a lot of posts for as much information as possible. I understand about interior colored parts on select models as I have a 03 Ford Thunderbird Pacific Coast edition witch was a 1000 limited production model with light ash interior. I'm going
to keep reading and thanks!
Does anyone have a picture of the shock stuffer in place.
I'm getting my wheels balanced and I'm curious if they were removed.
I've seen a picture of the shock stuffer but never in place.
Les
Les
ljorges (08-06-2017)
That long yellow tab connects to a 1 1/2 inch of white plastic that is hidden in the boot.
Then the stuffer will come out.
I've had my AE manual vert for a year and a half now and still smile every time I crank it up. Had to replace a headlight gear ($45 and 1 1/2 hours of easy work) and a battery. I drive it nearly every day and it has been everything I hoped it would be. It took some looking and patience to find the right one, but I was set on that particular color combination and had to have a vert and manual tranny.
