C5 harmonic balancer question
Old Apr 12, 2017 | 11:01 PM
TRS's Avatar
TRS
Default C5 harmonic balancer question
I recently purchased a 99 c5 that has been a joy to drive. I'm happy with the way it is set up so I have been wanted to put some money into the general maintenance aspect of it. During the PPI, my mechanic told me it had a 'slight' wobble in it - at the time I wasn't aware of how common an issue this is - my questions are:
1.
I don't really know what a 'bad' wobble vs a 'slight' wobble look like so I posted a video - if anyone could take a look and share an opinion that would be great.
2. This car is DD - is the powerbond pulley and ARP bolt the route to go?
3. I read a bit on people changing the underdrive pulley as well - is this needed or a performance mod
4. I would also change the A/C tensioner too (mechanic said it was 'slightly leaning') - is there anything else that I should change while I am at it? Gaskets/other pulleys etc?
Thanks!
CLIFFS: Posted a video, how bad is the wobble? Which kit is preferred and what else should I change while in there.
Old Apr 12, 2017 | 11:07 PM
TRS's Avatar
TRS
MODS: just occurred to me that I should have posted this in the TECH section - so I just did. Please close this one of necessary, thanks.
Old Apr 12, 2017 | 11:09 PM
pjdbm's Avatar
pjdbm
Hi,
I have a 99 too and mine is like that or perhaps worse.
I am not sure if I will be doing it anytime soon but will keep an eye on it.
I do have a bunch of parts coming in from Rockauto, the two tensioners, the two pulleys and a gator belt.
looking at your youtube vid, I wouldn't replace it just yet.
Old Apr 13, 2017 | 05:04 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
1.https://www.youtube.com/watch?v=wNXZr0m8_xg
Thanks!
I had the gm, crap designed to fail balancer, repealed and replaced with a powerbond and new gm pulleys and tensioners and gm belts...no more wobble or chirping...do yourself a favor and just DO IT...
BTW...I used a new gm bolt and also make sure they put a new front crank seal while its apart...
Old Apr 13, 2017 | 07:41 AM
Slo Yelo C5's Avatar
Slo Yelo C5
Just get it done. Mine has the same amount of wobble in a 2000, and I'm getting it done next week. I'm keeping the car forever, so going overboard. ATI is the "Ferrari" of balancers. I'm going ATI balancer ($400 for part), ARP bolt, and crank seal. I'm told it should be good forever with ATI balancer. $1,100 including parts and install. It'll be well worth it.
Old Apr 13, 2017 | 09:08 AM
tbrowne's Avatar
tbrowne
You don't need a $400.00 balancer if you're not making big power or racing. The PowerBond balancer will be more than sufficient and an OEM bolt is as good as any. ARP bolts are reusable and best for those that dissemble their engines frequently, again mostly those that are racing. Buy quality parts but save a few bucks for other things.
Old Apr 13, 2017 | 12:10 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default balancer
HEREHERE
To C5 harmonic balancer question
