Code C-1233
Old Apr 17, 2017 | 11:39 AM
Cosmic Charlie's Avatar
Cosmic Charlie
Default Code C-1233
Hi
Had my module re-done by ABS Fixer a few years ago for Code C-1214 and all good.
Now New Code Shows Up - Code C 1233 - (Right Front Wheel Speed Sensor Circuit Open ...)
A swap of the ABS module front wires to the front hubs (L to R) (R to L) and same code reports. (so the module is the problem)
I call ABS Fixer and he says I he can't fix that code - time for a replacement module.
Car re-sets the dash cluster shown icons on shut off to History, and on re-start all is fine until driven over 10 mph and then Code C - 1233 returns to the dash cluster display (icons) ...
Anyone have additional info / or can correct my understanding would be appreciated.
I was advised by ABS Fixer I can drive the car without the module installed without any issues except the ABS/Traction/AH not working.
Direct Email to sell me a working ABS module
(will buy with code C-1214)
(will NOT buy with Code C-1233)
Caesar5@comcast.net
(posted to WTB here as well)
Old Apr 17, 2017 | 11:46 AM
friou's Avatar
friou
You might want to call marc at vettenuts. He probably has what you need. Good luck!
Old Apr 17, 2017 | 01:00 PM
Cosmic Charlie
Called VetteNuts & ABS Fixer and both will call me if one is located ...
Old Sep 3, 2017 | 10:00 PM
Cosmic Charlie
Had My Air Bags try to repair code C-1233 and they failed and refunded me my $100
Then sent mine to Corvette_Shop and for $795 got a working module with lifetime guarantee, and $100 for my core so for $695 total cost - all good
this guy is Corvette_Shop:
http://www.ebay.com/itm/220929349650
100% Guaranteed to work like new- Over 125 modules sold and counting!
For sale is a newly rebuilt EBCM (electronic brake control module) that will fit ANY 2001-2004 Corvette, including Z06. This is a 100% genuine General Motors/Delco part. Guaranteed to work 100% like new, and comes with a LIFETIME WARRANTY! For the life of the product, simply send it back for replacement if it ever fails. I can offer this warranty because I have the utmost confidence in the quality of this unit. You will not receive ANY warranty with any other EBCM that you buy on eBay! This rebuilt unit is better than new because the faulty stock electrical components were upgraded with higher quality parts that will not fail. The stock unit is well known to be built with faulty components that WILL FAIL every time, guaranteed. Save your time and money by going with one that has already been rebuilt and upgraded! Again, a lifetime warranty is included! Don't take the risk of buying a new unit that comes with NO warranty, and will eventually fail!
FREE and FAST domestic shipping!
Low stock, order now!
**Core Unit Return REQUIRED. By purchasing this item, you are agreeing to send back your core EBCM module. You will receive a $100 refund for sending back a rebuild-able core unit. **Core unit is REQUIRED to qualify for warranty! Your warranty begins as soon as we receive your core unit. Your core is your old, non-working EBCM module. Please contact me before purchase if you do not have a core to send back.**
To Code C-1233
