from the title of this thread, I was expecting something different
If the vibration is at a certain speed but less noticeable at an even higher speed, it could be a minor bend in a wheel or the new tires need to be road force balanced.
I had the exact same thing and it was a bad wheel bearing. Try seeing if it goes away or gets louder in left or right turns, that way you can isolation which side of the car has the issue.
Same. I was gonna tell him to turn down the reggae.
