Increasing auto trans line pressure.
Old Apr 25, 2017 | 01:00 PM
wildazme's Avatar
wildazme
Default Increasing auto trans line pressure.
Hi all I just recently got a hypertech hpp3, yes I know it's an old model but I got it at a cheap price. I installed it and set the transmission line pressure to 50% firmer. I'm just wondering what the general consensus is on this, and if it will be safe to have on my car for the long run. Normal driving pretty much feels the same but under heavy throttle I can feel the shift more now. My current mods are an Airaid intake and magnaflow x pipe with dual straight tubes. Thanks in advance. Oh and the car is an 01 base vette.
Old Apr 25, 2017 | 01:32 PM
RBS_Z51C5's Avatar
RBS_Z51C5
Active Streak: 90 Days
I was always told that increasing line pressure will shorten the life of a transmission and that adding a mechanical shift kit like TransGo won't. Hopefully, somebody with more extensive knowledge will chime in
Old Apr 25, 2017 | 01:53 PM
wildazme's Avatar
wildazme
Not saying that's wrong hence why I'm asking but I believe almost everyone that gets a tune on there car, even dyno tunes I believe the tuners increase line pressure and change shift points etc. So if this was the case there would be a lot of broken transmissions no?
Old Apr 25, 2017 | 08:47 PM
tbrowne's Avatar
tbrowne
It can shorten the life of the trans but it's hard to measure how much. It depends on too many factors; such as how you drive, how old the trans is, how its been maintained. Two things to do: change the trans fluid and filter often and pull the shift lever down into third before making full throttle downshifts, which are brutal on the trans. Your trans should last a long time but be prepared for a rebuild in the future if you regularly drive it hard.
Old Apr 25, 2017 | 09:02 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
increased pressure= quicker shifts, less clutch slippage, less heat =more life !!!!!
To Increasing auto trans line pressure.
