Please help me identify the part!
While removing my steering wheel I noticed this...
(It's just the the left of the steering wheel tilt handle. black box with something red in it)
I couldn't get it in the pic but there is a thick harness wire plugging into it.
This is what is under my dash. Is any of this stock? The little blue connector with the purple and white wires going into it to the left of the yellow airbag connector says "Delphi" on it. and the bundle of wires look brand new and I've had this car for years! What could this be?? Super curious. Any thoughts greatly appreciated.
Is the car a manual trans??? Wire colors match up pretty well with a GM K Harness that might have been installed as a part of the GM Column Lock Recall Service.
If it is a manual and it is a K Harness and you have not yet installed an LMC5 you are betting that you will never have a weak or bad battery that fries the Relay portion of the K Harness and leaves you stranded..............
Here is a pic of a K Harness for your reference:
And here is what a K Harness relay looks like after the battery runs low:
