Can't find the thread ... Hyper flash solution
Old Apr 28, 2017 | 01:39 AM
Recon_Joe's Avatar
Recon_Joe
Default Can't find the thread ... Hyper flash solution
GEEZ ... you try and the forums for the Hyper flash solution thread and you're spending all day reading ... and not making very much head way. I remember reading about guys who came up with solutions other than buying the harness from Radioflyer.
Anybody got those thread locations saved? Thanks in advance!
Old Apr 28, 2017 | 02:30 AM
Tsumi's Avatar
Tsumi
https://www.corvetteforum.com/forums...ith-led-s.html
This thread has the information you need to make your own harness. Any three prong LED flasher (CF13 or CF14) will work.
If you aren't afraid of cutting into your wires, a harness isn't necessary. For the cost and time to make your own harness, I would recommend getting a cheap one off of an auction site. Radioflyer's looks nicer and better built but it's going to be hidden away in a relatively low stress environment…
Old Apr 28, 2017 | 08:25 AM
runner140*'s Avatar
runner140*
The "search" can be difficult....Google is your friend. Google your title
"hyper flash solution".
Old Apr 28, 2017 | 08:29 AM
FX VETTE's Avatar
FX VETTE
always use Google search
Old Apr 28, 2017 | 08:42 AM
GCG's Avatar
GCG
You can use a LED flasher like the one below. It can handle loads from 20mA to 20A without a problem.
Amazon.com: 3-Pin CF-13 Electronic Flasher Relay Fix For LED Turn Signal Light Bulbs: Automotive Amazon.com: 3-Pin CF-13 Electronic Flasher Relay Fix For LED Turn Signal Light Bulbs: Automotive
Or get one like this for just $35.99 and call it a day
Old Apr 28, 2017 | 08:53 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I do as well and it always leads me back to the forum!
Old Apr 28, 2017 | 09:39 AM
Recon_Joe's Avatar
Recon_Joe
Agree. And that's where it started. However there are countless threads with hyper flash solution in them.
Love this place but certain topics are a task to pul the info one needs. But at least the info is there some where ... and members are always willing to help each other out.
Thanks a bunch.
Old Apr 28, 2017 | 09:41 AM
Recon_Joe's Avatar
Recon_Joe
Same. Google first and there is always a link to our forums. But this particular topic (as well as a few others) have just a "few" threads discussing the topic.
But ... info i need is here
To Can't find the thread ... Hyper flash solution
