2xx/30/18 Square Setup
Old May 1, 2017 | 01:10 PM
Alexander K's Avatar
Alexander K
Default 2xx/30/18 Square Setup
Hello,
Was curious if anyone is running a similar square setup. My only worry was running the 30 in the rear as its circumference will be about 11% smaller than stock. I'm getting DW's and there were a lot of complaints about a soft sidewall. I thought running a lower aspect ratio would help with responsiveness, as well as lowing the car about an inch without effecting geometry. Not worried about AH as I never run with it on. Cosmetics would be a bit of a concern.
Let me know what you think as its the same price for 2xx/40/18 tires.
Old May 3, 2017 | 03:06 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Lots of people run a square set up for autocross and road racing. Check out that forum for more answers.
Old May 4, 2017 | 09:31 AM
Alexander K
Thanks YLO z06 but my concern was not in running square but running the 30ar tires which are smaller than oem. The wheel would be about 11% smaller in circumference.
Old May 4, 2017 | 11:17 AM
Quickshift_C5's Avatar
Quickshift_C5
I run 295/30/18 square setup with no issues whatsoever, and I've driven the car pretty hard to test. You won't have an issue.
However, I did swap the front wheels with another set that had 35 or 40 series on the front just to test some noises I was hearing. Don't do that. The car was VERY unhappy. It was fighting me just to go in a straight line, then I could feel it tug a corner and the system faulted out. It wasn't an issue when I simply turned off TC/AH. So...just pay attention to what you mount on the car. Simple as that.
Old May 4, 2017 | 01:46 PM
Alexander K
Thanks! got any pictures of the car? curious to see what the car looks like on 30ar. Especially if you're lower than oem height
To 2xx/30/18 Square Setup
