Rear tires
Old May 3, 2017 | 01:25 AM
jasonarty's Avatar
jasonarty
Default Rear tires
I am looking to replace my rear tires because the tread is worn out. What is a good tire that isn't expensive but also not cheaply made? Do I have to use run flats? Thank you for the help. Its on a 2001 coupe.
Old May 3, 2017 | 04:19 AM
chris308's Avatar
chris308
Hankook is a decent inexpensive tire. No you don't have to run run-flat tires.
Old May 3, 2017 | 07:08 AM
ZigZag's Avatar
ZigZag
What size are your rear tires ? Prices will range from $119 to $331 per tire depending on what you're after if it's a 275-40-18. If it's a larger tire like a 295-35-18 it will be more.
Old May 3, 2017 | 08:30 AM
I'd also recommend the Hankook Ventura V12 EVO tires. Been very pleased with mine.
To Rear tires
