Driver's Door won't open
Old May 8, 2017 | 05:49 PM
dalevitek's Avatar
dalevitek
1st Gear
Default Driver's Door won't open
Driver's door locks but intermittently will not open. Door Actuator faulty?
Old May 8, 2017 | 06:06 PM
Vanover's Avatar
Vanover
Does the pass.side work?
Old May 8, 2017 | 07:02 PM
Macleod52's Avatar
Macleod52
What you need to do is when you for sure unlock the car and the driver's door will no open, go to the passenger side and see if the door truly is unlocked (You can do this while sitting in the car too). If the door is still locked even after hitting the unlock button then chances are it's a bad relay in the door control module. Cheap fix if you're handy with a soldering iron.
To Driver's Door won't open
