Cooling system
It seems popular with antique car enthusiasts. Antique as in pre-WW2 cars non-pressurized systems. It's supposed to reduce corrosion between iron/aluminum/copper. But a C5 engine is all aluminum.
In a modern car with a properly functioning coolant system and radiator, IMO the potential problems far outweigh the benefits like its 350 degree boiling point or whatever specification Evans gives. Your coolant temp will actually be higher with Evans that antifreeze. Lots of people report problems with leaks and wear on the water pump. And you have to purge every drop of H2O before switching to Evans or it will create harmful byproducts. Just way too much trouble to hassle with for the supposed benefits.
I drive my car in 115 degree. Last summer, I got stuck in a slow moving fast food drive thru where I was basically just idling in extreme heat for 25-30 minutes, and the coolant still never went above like 232-233. Even when I'm driving hard in that summer heat and get my oil temp up to 250, the coolant temp has never given me concern.
Basically, if your car is overheating, I'd find and fix the source of the problem.
